need help I.D.'n this distributor
Old Nov 28, 2010 | 09:52 PM
1992CamaroRS305's Avatar
i need to I.D. this distributor cap and find out what yr/make its for.... cuz the distributor cap on my car i believe is the wrong one.... btw... i just bought a 92 camaro with a mid 80s TPI vette engine... or so they say... how can i I.D. the engine... anyone know where the vin for the engine is? the valve covers have the bolts in the center instead of around it. ty
Old Nov 28, 2010 | 10:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: need help I.D.'n this distributor
Looks like stock large cap HEI.
Old Nov 28, 2010 | 10:02 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I believe the '85 TPIs still used the large cap distributors. Any 82-86(ish) LG4 would have that dist. as well. If I'm not mistaken, it's also the same cap used on any pre-ECM (81-older), HEI distributors.
You basically have two choices, a large cap with a coil in it, or a small one with seperate coil (86ish-up).
I could be easily wrong but, I think any of the 'vette TPI motors had alum heads and the EGR valve was not under the plenum either.
Old Nov 28, 2010 | 10:48 PM
well thats a pic of the dist cap im looking for cuz the one i have is a cap with the coil to the side.... and the wires i have hanging around near the cap and coil are pink with black strip and white. my main problem is i have 12 volts going into the coil and the wire becomes hot when key is turned but i get no spark at the coil. it has a new cap, pick up coil, coil, and control module was tested 5 times and it passed, so im thinkin its the wrong coil/dist cap set up on my car
Old Nov 28, 2010 | 10:55 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
'80'S Vette engines have 3 letter code starting with Z
Old Nov 28, 2010 | 11:24 PM
k, kool.... next step is to i.d. the engine, then check ECM...cuz im hoping the didnt rig it up with a diff harness.... kinda looks like it. they had the electric fan and a few other things in the loop of the ingition wire that goes to distributor lol
Old Nov 29, 2010 | 12:27 AM
deadbird's Avatar
Engine: TPI 305/ v6
well thats a pic of the dist cap im looking for cuz the one i have is a cap with the coil to the side.... so im thinkin its the wrong coil/dist cap set up on my car
You'd have the wrong distributor then. The caps are not interchangeable between the the two styles of distributors.
Old Nov 29, 2010 | 12:32 AM
well the thing is, is that this car used to be a v6 and they put in a v8, but i dont know if they ever had it running.... and the wires hooking up to that dist on that pic are 2 of the 3 wires i have just hanging around, but ima try to I.D. the engine tomorrow to have more insight and post some pics of what it all looks like
Old Nov 29, 2010 | 06:50 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The wires look correct.
Old Nov 29, 2010 | 05:11 PM
i found a stamp under right cylinder head and it read MOO and it had three numbers on the left side of the engine kinda near the crank pull that read 638. anyone have an idea of what i have?
Old Nov 29, 2010 | 08:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The deck stamp is next-to-useless. The 638 on the side of the block means the complete casting number will be 14093638. It's a 1 piece RMS 350 block.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
