oil pressure sending unit
Old Nov 29, 2010 | 11:53 AM
1991TransAm's Avatar
Car: 1991 Trans Am GTA
Engine: 357sbc
Transmission: TH350
Axle/Gears: 2.73 stock rear
do you need it sending unit plug in to run and drive the car? Im going do a swap to a aftermarket gauge that dont use a sender, just a line to the gauge.
Old Nov 29, 2010 | 11:54 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil pressure sending unit
Are you carbureted or fuel-injected?
Old Nov 29, 2010 | 12:04 PM
Engine: 357sbc
Transmission: TH350
fuel injected
Old Nov 29, 2010 | 03:51 PM
Engine: 357sbc
Transmission: TH350
i want to do this tomorrow so i need to know.
Old Nov 29, 2010 | 04:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The car will most likely start and run without it if the fuel pump relay works, but it'd be best to keep it.
Old Nov 29, 2010 | 05:53 PM
Engine: 357sbc
Transmission: TH350
it runs with it unplugged
Old Nov 29, 2010 | 08:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Then you're good. How many wires are on it?
Old Nov 29, 2010 | 08:19 PM
Engine: 357sbc
Transmission: TH350
3 wires for the sending unit plug.
Old Nov 29, 2010 | 08:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the combined sender/switch, then. You could just leave it alone and put your mechanical gauge in the other oil port.
Old Nov 29, 2010 | 08:35 PM
Engine: 357sbc
Transmission: TH350
plus the fuel pump is hooked from the key to the computer. my brother just reminded me
Old Nov 29, 2010 | 10:30 PM
Pocket's Avatar
Car: 91 Trans Am
The extra two wires are a bypass in case the relay fails during a run. It wont hinder running
http://www.austinthirdgen.org/mkport...ta_sensors.jpg
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
