New c100 connector and OEM color wire??
Old Dec 1, 2010 | 08:56 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Where can a new c100 connector, weatherpack connectors and OEM colored wire be bought to rebuilt the engine bay harnesses?
Old Dec 1, 2010 | 10:20 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: New c100 connector and OEM color wire??
try painless wiring?
Old Dec 2, 2010 | 09:39 PM
Pocket's Avatar
Car: 91 Trans Am
www.mouser.com
Ive found everything but the C100/C207/C221
Various sellers offer wire. You want TXL jacket for whatever size you need. 3rd gen minimum is 18ga, max is 10ga. Anything in the vicinity of fuel requires teflon coating IE TBI injectors/in tank pump wiring
Old Dec 2, 2010 | 09:49 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
I have a spare c100, and computer/engine harness side c207, and a bit of extra of weatherpack connectors. my c100 is missing some pinouts as i need them, if your interested
Old Dec 3, 2010 | 03:08 PM
Brads RS's Avatar
www.larryselectricsite.com sells connectors
Old Dec 3, 2010 | 03:43 PM
Pocket's Avatar
Car: 91 Trans Am
They have the common connectors universal to TPI/LTx/LSx engines. No Fbody specific body connectors
Old Dec 6, 2010 | 07:25 AM
Brads RS's Avatar
Get me a part number for the connectors and i will see what i can do. I work for a company that makes and repairs automotive wiring harnesses.
Old Dec 6, 2010 | 07:49 PM
Pocket's Avatar
Car: 91 Trans Am
Would if I could. Ive been hunting the info for a long time
See if the PN listed in this is valid
https://www.thirdgen.org/forums/elec...ctor-info.html
Might find it by association
In all the JY cars Ive snooped, Ive never found another body connector like whats in 3rd gens
Old Dec 7, 2010 | 07:37 AM
Brads RS's Avatar
I think i may have found it.
Go to Delphi site. http://connectors.delphi.com/dcsgdmcs/homepage.aspx
type in part number 12015509 or 15492519 (25 Way Black Metri-Pack 280 480 630 Unsealed Male Connector Assembly)
and 12020629 (17 Way Black Metri-Pack 280 480 Unsealed Male Connector)
and 15492518 (42 Way Black Metri-Pack 280 480 630 Unsealed Female Connector Assembly)
If these are what you are after i will see if i can get some on order.
Old Dec 7, 2010 | 07:46 AM
Pocket's Avatar
Car: 91 Trans Am
You the man!
15492519 is a good PN. Check the PDF drawing, right on
http://connectors.delphi.com/DCSGDMC...rtNum=15492519
Cant locate the rest or the C100 cover, but the engine side C100 is plenty useful. Only $3.25 each too
Old Dec 7, 2010 | 10:02 AM
Brads RS's Avatar
I will get some on order for the future. If anyone needs them now you can get them from mouser. Or PM and i will let you know when i get some in.
Old Dec 7, 2010 | 10:50 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
very interesting, good to see we can start with a fresh wiring setup instead of cutting up the factory harness. my setup's way too far ahead to make use now, but maybe next time i can tuck away the factory harness for future safe keeping
Old Dec 14, 2010 | 12:01 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Nice info... keep it coming
Old Dec 14, 2010 | 07:32 AM
Brads RS's Avatar
I now have c100 connectors, and terminals if anyone is interested. I Also have access to most other connectors for thirdgens, just shoot me a part number.
Old Apr 4, 2011 | 02:42 AM
rock861261's Avatar
did you find which c100 partnumber fit a 90 -92?
Old Apr 4, 2011 | 07:39 AM
Brads RS's Avatar
These should be good part numbers and will fit the 92 f body
Old Apr 4, 2011 | 10:47 AM
rock861261's Avatar
that makes me happy great research.... now if i could only find a good place online for some factory colored txl wire....
Old Apr 4, 2011 | 12:11 PM
Brads RS's Avatar
What colors and sizes do you need?
Old Apr 4, 2011 | 01:33 PM
rock861261's Avatar
some orange green/white gray pink 18ga red 10ga just what i can think of
rock861261's Avatar
i hate splicing power wires together i would rather repin and pay alittle extra then have trouble down the line
Old Apr 5, 2011 | 07:38 AM
Brads RS's Avatar
PM me with the lengths and i will get you some prices, and my work email.
Old Jan 27, 2014 | 12:55 PM
bryanwood74's Avatar
Car: 1988 Camaro
Engine: 5.3L LM7
Axle/Gears: 3.73 1LE '90 Disc
BradRS, I am interested in taking a PSI Conversion standalone harness (HAR 1012) and instead of cutting my under dash wiring to hook up the 5 or so wires it needs I'd like to get a C100 and have the pins wired where needed. Would you be interested in doing this? I'd be happy to pay ya, if it makes the harness plug and play and I don't have to cut up my old harness, etc...
Old Apr 29, 2016 | 02:47 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
Adding to an old post...
C100
Interior Side - 15492518
Lock B - 12015511
Lock C - 12015510
Engine side connectors
25 Pin - 15492519
17 Pin - 12020629
Pin locks are the same as above
25 Pin stabilizer - 12162412
17 Pin stabilizer - 12162413
Unsealed pin part numbers
Pins, 280 Male;
12084586 5.0-3.0 Tin Brass Tin
12129498 3.0-2.0 Tin Brass Tin
12020116 1.0 Tin Brass Tin
12034047 0.80-0.50 Tin Brass Tin
12066271 0.50-0.35 Tin Brass Tin
12020782 0.35 (2 Req’d.) Tin Brass Tin
Pins, 480 Male;
12033820 5.0-3.0 Tin Brass Tin over Copper
12052827 3.0 Tin Brass Tin over Copper
12020120 2.0-1.0 Tin Brass Tin over Copper
12020119 0.80-0.50 Tin Brass Tin over Copper
12066269 0.50-0.35 Tin Brass Tin over Copper
12020784 0.35 (2 Req’d.) Tin Brass Tin over Copper
Pins, 630 Male;
12066493 5.0-3.0 Tin Brass Tin over Copper
12052826 3.0 Tin Brass Tin over Copper
12020365 3.0 (2 Req’d.) Tin Brass Tin over Copper
12020126 2.0-1.0 Tin Brass Tin over Copper
12020125 0.80-0.50 Tin Brass Tin over Copper
12033972 0.80-0.50 (2 Req’d.) Tin Brass Tin over Copper
12066454 0.50-0.35 Tin Brass Tin over Copper
Pins, 280 Female;
12015858 5.0-3.0 Tin Brass Tin
12129494 3.0-2.0 Tin Brass Tin
12034046 0.80-0.50 Tin Brass Tin
12052217 0.50-0.35 Tin Brass Tin
12162597* 3.0-2.0 Tin Brass Tin
12162595* 1.0-0.80 Tin Brass Tin
12162596* 0.50-0.35 Tin Brass Tin
Pins, 480 Female;
12084595 5.0-3.0 Tin Brass Tin
12052221 3.0 Tin Brass Tin
12124304 2.0-1.0 Tin Brass Tin
12015860 0.80-0.50 Tin Brass Tin
12052219 0.50-0.35 Tin Brass Tin
12020366 2.0-1.0 (1 Req’d.) Tin Brass Tin
Pins, 630 Female;
12084590 5.0-3.0 Tin Brass Tin
12052224 3.0 Tin Brass Tin
12084596 5.0-3.0 (2 Req’d.) Tin Brass Tin
12015870 2.0-1.0 Tin Brass Tin
12015869 0.80-0.50 Tin Brass Tin
12020035 0.80-0.50 (2 Req’d.) Tin Brass Tin
12052222 0.50-0.35 Tin Brass Tin
Old May 10, 2016 | 10:10 AM
Pocket's Avatar
Car: 91 Trans Am
Nice info. Any chance you found the covers for the engine side C100 connectors? I couldnt even find discontinued PNs
Old May 10, 2016 | 11:19 AM
gixxer92's Avatar
Engine: 7.0L, 6.2L
All of the information was in a PDF off of - http://www.powerandsignal.com/
One would think that I could go back and find it relatively easy... nope. I know I downloaded the PDF at home. I will look tonight in my downloads folder I'm thinking it's still in there or in my good info folder within my 1986 Camaro folder.
eightsixseven
Dec 16, 2024 01:50 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
LT1Formula
Aug 20, 2015 09:36 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
