Want to replace speedo to 140 mph version
Old Dec 10, 2010 | 02:21 PM
nailhead77's Avatar
Car: 1985 Trans Am.
Engine: 305 w/4bbl
Transmission: stock
Axle/Gears: stock
Hey guys, im putting a 350 in my 85TA (carb). I want to change the speedo to the 140mph version like the formulas. Will i have to make any adjustments?
Old Dec 10, 2010 | 02:44 PM
ianclark's Avatar
Re: Want to replace speedo to 140 mph version
Disconecting the spedo cable from the back of the instument cluster is a PITA!
Old Dec 10, 2010 | 04:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Is there a cable-driven 140 for your application (I was thinking that all Bird 140's were electric)?
JamesC
Old Dec 11, 2010 | 09:09 AM
nailhead77's Avatar
Car: 1985 Trans Am.
Engine: 305 w/4bbl
Transmission: stock
Axle/Gears: stock
Im not sure about the cable driven 140mph speedo. If i cant do that ill just get a replacement like the one i have already. The trip wont reset on the one i have....drives me crazy. I was hoping i just had to disconnect the cable from the back and simply put in on the new one....sounds like not that easy?
Old Dec 11, 2010 | 09:23 AM
JamesC's Avatar
Cable driven to cable driven and electric to electric is a simple swap.
JamesC
Old Dec 11, 2010 | 09:56 AM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
If your speedo is electric, which it should be, it is super easy. Remove the instrument cluster from the dash. It is a pain to get past the steering column, but it comes out in one piece. Remove the **** off the trip-odometer reset button so you can get the clear cover off. Remove the screws holding the clear plastic cover on and then the three or four screws on the back holding the speedo and circuit board to the cluster assembly. Install the 140mph speedo and reassemble the cluster.
When you buy a 140mph speedo you need to get one with the circuit board. The one with your current speedo will not work. This really is a plug and play job and the biggest pain will be getting the speedo cluster out of the car.
I have done this a couple of times and it has always worked out great.
Old Dec 11, 2010 | 11:40 AM
JamesC's Avatar
Originally Posted by jharrison5
If your speedo is electric, which it should be....
I didn't think Birds went electric until 86....
JamesC
Old Dec 11, 2010 | 03:35 PM
nailhead77's Avatar
Car: 1985 Trans Am.
Engine: 305 w/4bbl
Transmission: stock
Axle/Gears: stock
Thanks fellas. im pretty sure mine is cable driven. Ill try to find a replacement.
Old Dec 17, 2014 | 03:14 PM
kuddybing's Avatar
Car: 85 Trans Am
Engine: carbed 350 four bolt
Transmission: 700R4 with shift kit
Axle/Gears: 373's
Im doing the same 85TA 350 (already in and a hard hitting mother) 85mph to a 140mph speedo... far as I can tell there are none for our years (unless theres aftermarket ones havent looked yet) alot of people swap to a 87+ clusters and convert to electric are u can go down in years 82-84 and they go140mph and 160mph are so iv read but I guess they look a little bit diffrent but thats what iv dug up so far
Old Dec 17, 2014 | 03:18 PM
kuddybing's Avatar
Car: 85 Trans Am
Axle/Gears: 373's
Hawks does a overlay and recalibration but I think u might have to call em to do it tho
Jorlain
Aug 24, 2022 05:11 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
