does ecm need the VSS signal?
Old Dec 13, 2010 | 01:52 AM
540sx!'s Avatar
Car: 240sx
Engine: 327sj(334) sbc , tpi, turbo
Transmission: tko500
Axle/Gears: 3.54 31 spline axles
I have swapped a 327 sbc into my 240sx and have stewart warner electric speedo hooked up to the electronic speedo sender on my tko-500.
I have had to intsall the 91 TPI intake and smog equipment to make my swap legal in cali.
trying to figure out if I need to find a way to convert the electic sender to go directly to ecm. guessing that any function that requires the vss will not work in the ecm(min vehicle speed for...) with out it, will this be an issue with tuning?
i will be contacting tremec tomorrow to find out what the electric sender is putting out.
Old Dec 13, 2010 | 02:38 AM
540sx!'s Avatar
Car: 240sx
Re: does ecm need the VSS signal?
never mind,
Just figured out that the speedo outputs ppm at during the calibration,
i can enter ppm in the bin file.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
thunder57
Nov 7, 2015 02:28 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lewandom
Oct 1, 2015 08:15 AM
