Coolant fan wont turn on.
Old Dec 18, 2010 | 11:34 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Ok guys. I need help here. Here is a picture of my wiring diagram below. I had it connected wrong. Instead of having the 335 wire (DarkGreen/White wire) connected to ECM Terminal C1, it was grounded to the frame. So when I would turn on the key, the fan would turn on immediately. So today I disconnected the ground wire from the coolant relay and connected it to the DarkGreen/White wire. This DarkGreen/White wire grounds its self when a certain temperature is reached, which ultimately closes the circuit and turns on the fan. Well that didnt happen. I connected everything like how it is displayed in the wiring diagram and the fan wouldnt turn on. So i jumped the "ECM" wire to ground (using a wire with 2 alligator clips) and the fan turned on. Its obvious that the ECM is not grounding the fans ground. The ECM is a Reman from Autozone (6 months old), I have a custom burnt EPROM with the "fan turn on" set at 190* and turn off at 183*OOHH. and the engine temp reached 200* and the fan still wouldnt turn on. Im planning to do a continuety test from the ECM C1 terminal and all the way down to the other end near the Coolant fan relay. Is there anything else that I should test guys before I go out and buy a new Coolant Temperature Sensor?
CORRECTION!!!!
I spoke with the TGO member who programmed my EPROM earlier. I was wrong about the fan turn on temperature. The programmed setting is set to turn on at 190* and turn off at 183* .
Old Dec 18, 2010 | 11:41 PM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
Re: Coolant fan wont turn on.
Originally Posted by Chevy86 IROC-Z
Ok guys. I need help here. Here is a picture of my wiring diagram below. I The way I had it connected was instead of having the 335 wire (DarkGreen/White wire) connected to ECM Terminal C1, it was grounded to the frame. So when I would turn on the key, the fan would turn on immediately. So today I disconnected the ground wire and connected it to the DarkGreen/White wire. This DarkGreen/White wire grounds its self when a certain temperature is reached, which ultimately closes the circuit and turns on the fan. Well that didnt happen. I connected everything like how it is displayed in the wiring diagram and the fan wouldnt turn on. So i jumped the "ECM" wire to ground and the fan turned on. Its obvious that the ECM is not grounding the fans ground. The ECM is a Reman from Autozone (6 months old), I have a custom burnt EPROM with the "fan turn on" set at 183*. OOHH. and the engine temp reached 200* and the fan still wouldnt turn on. Im plannung to do a continuety test from the ECM C1 terminal and all the way down to the other end near the Coolant fan relay. Is there anything else that I should test guys?
How do u know your temp was 200 ??? The gauge might be off !!!!!
first check the temp from gauge with a laser gun thermometer !!!
Thats what i would do .
Old Dec 18, 2010 | 11:43 PM
Good call! Ima have to buy a 9 volt battery tomorrow. When shooting for a reading, Should I shoot the lazer at the area surrounding the Temp Sensor?
Old Dec 18, 2010 | 11:45 PM
i would use the thermostad housing ..at the temp sender i think its to close to the exhaust !!!
or where the return line goes to the radiator ..( FROM THE ENGINE )
Old Dec 18, 2010 | 11:47 PM
opps. i didnt mean the temp sender in the heads/headers. I mean the temp sensor that is just below the throttlebody, infront of the intake manifold base.
Old Dec 19, 2010 | 06:13 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You can test the CTS for correct operation with a DVM
185 Ohms @ 210F,
3400 Ohms @ 68F,
7,500 Ohms @ 39 F.
Old Jan 6, 2011 | 12:57 AM
Guess what guys!According to my temp gauge, the IROC reads 200*. Well today I let the engine idle until all of a sudden the fan kicked on. I zapped the thermostat with a laser thermometer and the temp was 191*. So I thought there was a problem in the wiring the whole time or the ECM when the problem was the temp gauge. Hell, its 20* off. I thought it was 200 when the coolant was actually 180*. Dumb temp gauge. Thats another fan issue resolved for the books. Thanks for all the info and help guys. .
eightsixseven
Dec 16, 2024 01:50 PM
Fronzizzle
Mar 18, 2019 08:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
