TPS Question
Old Dec 23, 2010 | 05:11 PM
BlueDevil88's Avatar
Car: 1988 Firebird "Bertha"
Engine: 5.7 Liter TPI with minor mods
TPS Question
While doing research today, I learned that the 91 and 92 cars did not have adjustable throttle position sensors. I have a motor out of a 92 Z28 in my 88. It has an adjustable tps. How much would this effect the engine? I suspect its out to begin with, because it has a dead spot in the throttle. (I've been tinkering with the car for a while now, but I have to get it up to par now cause I wrecked the beater.) If anyone has a clue, it would be very helpful. It would be interesting if this is the root of most of my problems. Minus the obvious lack of a few vacuum hoses. Lol
Old Dec 23, 2010 | 06:54 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: TPS Question
oops
Old Dec 23, 2010 | 08:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPS Question
Originally Posted by BlueDevil88
the 91 and 92 cars did not have adjustable throttle position sensors. .. It has an adjustable tps. How much would this effect the engine?
'730 TPI ECM takes the TPS figure it first sees when key turned on and uses that as base figure.( so long as it is within range )
Does not require setting to .54 V as on earlier '165 TPI computers.
Put a DVM on the TPS and measure the resistance .
Should be smooth increase across total opening range
Old Dec 23, 2010 | 11:28 PM
Re: TPS Question
I'm not sure which ecm is in the car. I have the one in the car it is running with now, and a extra one in a box of misc. parts I was given when I traded the car. I am guessing there would be numbers on the ecm's that would tell me? And, If I do infact have a dead/dying tps with a '165 ecm, would it matter if I got a non adjustable one or not? I'd rather not have the hassle of having it be adjust able.
Old Dec 24, 2010 | 02:09 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: TPS Question
'90 -'92 TPI with speed density setup ( no airflow meter on the intake plumbing ) are '730 ECM
Old Dec 24, 2010 | 12:17 PM
Re: TPS Question
Well, I have a MAF Set up, so I definitely have the older computer. I'll get the tps voltage checked soon as this snow goes away.
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
