Radiator fan switch. Think I'm doing it wrong.
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
This may seem pretty dumb to you guys, but I'm new to this. I ran two wires into my cabin to connect to a switch so i can flip the radiator on (the old heat sensor in the head is broken and a replacement is...let's just say excruciatingly expensive), the only trouble is I'm almost positive I either have waaaay to small a gauge or I'm doing it wrong. When I make a connection the wire heats up REALLY fast, so i break them apart to keep from burning anything up. I am running the HOT wire through the switch. Is this incorrect? Should I be running the ground wire instead? if that's the case, is using a thin gauge solid wire okay for the job?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
FanFare
The correct way to wire up a the fan switch is to have the switch ground the coil of the fan relay.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Happy Racing!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: FanFare
The fan switch (located in the pass side head) is a single wire, and it is a ground. When the temp gets up, the switch makes a ground contact for the fan relay.
So - there should be NO hot wire. You just need to connect the fan switch wire to one side of your switch, and connect the other side to a ground (any metal in the car).
If you have a hot wire in the config, then you are shorting out that hot wire and that's why it's getting hot!
Re: Radiator fan switch. Think I'm doing it wrong.
Soooo, where does the hot wire run then? Just straight from batt to fan?
Car: 1992 RS
Engine: Carbed 350
There shouldn't be any hot wire - there is no hot wire on a fan switch!
That's why I'm saying that you are shorting out - because if you are connecting a hot wire to the fan switch in any manner, the fan switch is a ground, and thus you are creating a short.
I'm assuming you are trying to use a switch that illuminates and thus needs a hot wire to light up? If so, then you need to make sure that ONLY the switch is getting the hot, and that it's not getting transferred within the switch to the fan switch wire.
I used a relay with mine - when I turn on the switch, it gets power from the fuse box, illuminates, and sends + out to the relay, which activates the relay, which connects the fan switch wire to a ground.
I suppose maybe you could use a 3 prong switch, that is getting the + all the time, and gets a ground when you turn it on - the ground thus would make a circuit which would light the switch (since it already has a hot connected all the time), and transfer the ground to the fan switch wire. You'd have to connect the wires differently to the switch that how it's marked. Might work that way.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
He's talking about the hot wire to the fan, not to the switch.
Car: 1992 RS
Engine: Carbed 350
OK, sorry - I'm getting confused
If you are just running a switch, to power the fan directly, without making use of the fan switch wire, then yes, directly from batt to fan. You just can't put any + power to the fan switch wire, or you'll get a short.
The absolute easiest thing to do, is to go to any auto parts store and get a seperate fan controller - they are as low as $35, simple to wire with complete instructions, and puts you back to an automated fan operation so you don't forget to turn the fan on and overheat. Most are adjustable (not the cheaper ones). They use a probe that gets stuck inbetween the fins on the radiator for temp sensing, and turn on the fan at a predetermined temp. I use a Flex-a-lite model, was $100 but the best $100 I never spent - it's fully adjustable, has provisions for A/C, dual fans, and manual on/off switches. Only took an hour to install, and has performed flawlessly for 3 years now.
