Injector Wiring Question....
Old Dec 30, 2010 | 12:15 AM
globalco's Avatar
I recently installed a rebuilt wiring harness in my 92Z along with a rebuilt engine. It just occured to me that though the injector wiring pretty much lays about where it used to be that I may have somehow crossed one over the other. I don't currently have a way to determine this.
Is there a way to know which connector goes to which injector? The Haynes book is a bit confusing as far as wiring colors.
A diagram with colors would really help.
Old Dec 30, 2010 | 12:22 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Injector Wiring Question....
They are batch fired, it doesn't matter which one is on where, as long as they are all on.
Old Dec 30, 2010 | 04:13 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Left and right banks are batch fired seperately.
Injectors on driver's side will have a black/pink wire and a dark blue.
Injectors on the passenger's side will have a black/pink wire and a dark green.
Old Dec 30, 2010 | 02:30 PM
globalco's Avatar
I understand the banks firing seperately, the wiring is set up in sets of two, two going to 1-2, 3-4, 5-6, 7-8. My question is, according to you color scheme, does 1 and 3 get black/pink or dark blue and the same with 2 and 4?
Am I explaining this correctly, I am trying to determine which injector gets which plug.
Thanks again
Old Dec 30, 2010 | 02:32 PM
globalco's Avatar
Didn't see you post Don, thanks I think I understand.
Street Lethal
Apr 30, 2019 12:14 PM
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Bryan F
Aug 18, 2015 02:28 PM
