help radio doesnt work!!!
Old Jan 10, 2011 | 12:10 PM
Pino25's Avatar
i have a 91 firebird v6 3.1 ok heres my problem i had a factory radio i wanted to switch it out with a after market radio so i pulled out the old radio an i accidently cut the main harness i dont know why i did that but when i realize it i repaired the wires matched them back up and now my radio doesnt work all of the wires are correctly matched an i got a test light and tested the wires i have one power wire when the key is on im pretty sure i should have two an i checked my radio fuse it was ok any ideas??? thanks Mike
Old Jan 10, 2011 | 12:34 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Radio 2 Go
Did you test your wiring repairs with the old, known to be working, radio?
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Jan 10, 2011 | 12:39 PM
Pino25's Avatar
Re: Radio 2 Go
yea i fixed the wires an plugged in the old radio an it doesnt work
Old Jan 10, 2011 | 01:37 PM
NINÅ's Avatar
Transmission: 765R4
Radio Active
One wire is for main radio power, the other is for memory.
Make sure the
yellow wire has power.
The
orange wire is for memory and should have voltage on it regardless of key position.
If you’re putting power into the radio but it doesn’t turn on the display
(never mind speaker wires for the moment) the radio might be defective, which you can verify by bench testing.
Happy Racing!
Old Jan 10, 2011 | 01:43 PM
Pino25's Avatar
Re: help radio doesnt work!!!
yea yellow has power but the orange doesnt an the display doesnt light up but it worked before i took it out of my truck and the factory radio doesnt light up either
Old Jan 10, 2011 | 07:34 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
go back to your main jumper spot where all your constant power conections are i think its under dash drivers mounted by the hood release but high up (includes removing underdash panels and side kick panel) it should look like a mess of orange wires like seriously a mess of wires then try to trace the wire for your radio
Old Jan 10, 2011 | 07:45 PM
vjgillespie's Avatar
Car: !991 RS Camaro
Axle/Gears: 4.10 4th gen
If the (orange) memory wire dosent have power the radio won't work. Has to have both power wires. If you can't trace the problem you can splice into another wire that has constant power.
Old Jan 10, 2011 | 07:48 PM
Red 87 GTA's Avatar
i would make shure that you dont have a melted wire or somthing weird though taping another will get your radio to work dont ignore the other wire going blank
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
