h4 bulbs? need answers by 12am.
Old Jan 15, 2011 | 07:59 PM
Guest
Guest
Posts: n/a
My H4 bulb is jingling inside it shouldn't do that i know for sure. Would that cause headlight flickering and also Is 90/100W to much shouldn't i be running 55/65W
Please Get back to me asap.
Old Jan 15, 2011 | 08:16 PM
Guest
Guest
Posts: n/a
Re: h4 bulbs? need answers by 12am.
Bulb doesn't come on at all. So would this caues flickering also think bulbs are to high of watt's in there is 90/100W need answers.
Old Jan 15, 2011 | 08:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Bad/ loose ground wire to headlight?
Old Jan 15, 2011 | 08:26 PM
Guest
Guest
Posts: n/a
Ok I'll have to check that out but would lower the watt's help or no.
Old Jan 15, 2011 | 08:36 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
If the bulb is jiggling around the flickering could easily be the result of your connection at the headlight. I would definitely check your connection there for oxidation/loose fit. As far as the wattage is concerned it shouldn't matter however thats assuming its wired correctly with an appropriate gauge wite and your electrical system in general is in good shape.
Old Jan 15, 2011 | 08:51 PM
Guest
Guest
Posts: n/a
Electrical is in good i cleaned all the electrical all off. Wiring is fine but i No the h4 bulb i took two of them out they have some wierd broken pieces jingling in the bulb not the headlight. So i bought new headlights also 55/60W because these are 90/100 watt that's too high and will overload the system without a wiring harness won't it?
Old Jan 15, 2011 | 09:03 PM
Well thats what I mean about having them wired correctly. Even the stock headlights were pushing the abilities of the factory wiring so trying to run 100 watt H4s off the factory wiring would not be a good idea. Of course even the 60s I think should be run off a relay and separate wiring harness. Again even with stock headlights youll notice a difference in the headlights brightness if you run them off a relay because the gauge wire used is so light and so long of a run for the amount of current being drawn theres just too much of a voltage drop in the wiring itself. Draw more current youll make it even worse and risk things like melting your headlight switch.
Old Jan 15, 2011 | 09:08 PM
Guest
Guest
Posts: n/a
ok so buy a relay harness.
Old Jan 15, 2011 | 09:16 PM
Yes, I think that would be a very wise idea. Keep in mind you dont necessarily have to buy one pre-made. I dont know how much they cost but you can make your own fairly cheap if you know what your doing.
Old Jan 16, 2011 | 05:30 PM
Guest
Guest
Posts: n/a
Only 25 bucks for a pre made one i bought one before i couldn't get the high beams on for some reason.
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
