Ignition change up, need some opinions
Old Jan 16, 2011 | 04:34 PM
cmbtmdc's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI
So i have had an issue with the key being stuck in the ignition, i took apart my steering column and i can take the key out as long as the cylinder is not in the steering column.
http://www.youtube.com/watch?v=IlXV38RI6RY
I am thinking about just cutting the wires from the cylinder and relocating the cylinder so that I can take the key out and rigging up a push button where the cylinder was.
Is it possible to replace the turning mechanism with a push button start or would it be easier to make a turning mechanism to turn the engine over when I have the key in the cylinder
Old Jan 16, 2011 | 04:44 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Ignition change up, need some opinions
Not really. See the ignition cylinder in the steering column is just a lock cylinder. Your actual ignition switch is mounted a bit further down the column. Now your ignition switch has multiple positions on it so its not just like a push button. If you were going to try and replace it you would need at least a switch and a button. However personally I would just rather fix whatever causing the issue in the first place.
Old Jan 16, 2011 | 04:54 PM
cmbtmdc's Avatar
Engine: 305 TBI
yeah i wanna fix it but i cant narrow down the issue, i was thinking of just relocating the lock cylinder so that i can use the key for the VATS system and find a way to turn the ignition at the column with something else. I already tested to see if it would work with a pair of pliers and it worked just fine as long as the key is in the lock cylinder
Old Jan 17, 2011 | 06:27 PM
cmbtmdc's Avatar
Engine: 305 TBI
so i figured out what i am going to do, im going to relocate the lock cylinder that the key is stuck in and then put a new cylinder with a key without the VATS codes in the steering column just so that it will turn the ignition, seems to be the simplest way to get this to work
Out-Cast
Mar 22, 2019 09:39 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Thornburg
Aug 25, 2015 01:46 AM
92camaroJoe
Aug 13, 2015 06:07 AM
