Headlight operation.... is this correct?
Old Jan 18, 2011 | 12:30 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I'm new to 'birds so forgive me if this is common knowledge.
I am under the impression that the marker lights on my '91 can be turned on WITHOUT the headlights going up... is this correct?
Currently, if I just turn the parking lights on, my headlights pop up. I didn't think they were supposed to.
Old Jan 18, 2011 | 01:29 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Blow It’s Door Off
Somehow power is getting to the Headlight Door Module when it‘s not supposed to.
It might be a faulty headlight switch.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the brown wire at the headlight switch.
Is there power there when the headlight switch is in the marker lights position?
If yes, disconnect the
brown wire at the switch.
Is there STILL power there when the headlight switch is in the marker lights position?
If yes, replace the switch.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Old Nov 1, 2015 | 09:58 AM
gormant1's Avatar
Car: 91 Firebird Formula
Transmission: 700-R4
Re: Headlight operation.... is this correct?
Did you ever figure out whats causing this? I'm having the same issue on my 91 Formula.
Old Nov 2, 2015 | 05:08 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I had that issue before. It was the switch causing it on mine. I figured it out because the lights would vary depending on how hard I pressed the switch itself. Then it stopped responding to the varying pressures. Swapped out the switch and haven't had that issue again.
Veaceonee
Sep 29, 2016 08:15 PM
nova983
European Region
Nov 2, 2015 12:15 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
