fuel pump not working help
Old Jan 22, 2011 | 09:10 PM
racersedge1821's Avatar
Car: 1991 Camaro RS
Engine: 383 procomp heads comp 280h cam
Transmission: 700R4 with monster tran. rebuild
k guys off subject i'm doing a camaro project with a buddy of mine we have swapped a 1995 camaro 3.4 engine trands and every piece of wiring from the donor to the new 1996 chassy what is going on is we have spark but the fuel pump gets no fire checked fuel pump relay not sure if thats it or not have checked all the fuses in-car and underhood.the color of wires coming off the fuel pump are purple,black and grey need help if u guys can we are stumped would be sweet if i could get a nice detailed wiring diagram of the fuel pump wiring ty
Old Jan 22, 2011 | 09:15 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: fuel pump not working help
since the 96 would have a 3800 and you put a 3400 in it maybe incompatible fuel pumps?
do you wanna just connect a battery to it and see if you can get power?
Old Jan 22, 2011 | 09:23 PM
Car: 1991 Camaro RS
yes that would be ok for now but we did take the pump difference in consideration so we swapped the 3.4 pump and tank also
Old Jan 22, 2011 | 09:34 PM
Car: 1990 camaro RS
Engine: 305 TBI
kk grey wire is pump power on almost all GM cars what are the other colors so i can tell you the ground
Old Jan 22, 2011 | 09:44 PM
Car: 1991 Camaro RS
purple black and grey are the three coming from the sending unit/pump and also why is the the fuel gauge pegged out at full?bad ground perhaps?
Old Jan 22, 2011 | 09:47 PM
Car: 1990 camaro RS
Engine: 305 TBI
yes bad ground and since they share a ground that would be why your pump isnt working lol, looks like you need to fix that and you should be good, black is ground good luck
Old Jan 24, 2011 | 10:47 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I'm doing a swap,3.1 into a 86 bird.the weather has me on hold.But before I stoped work the fule pump wasn't turning on yet the gauge was peged out like racesedge said his is doing.do the wires run through the car back or under the car?
Old Jan 25, 2011 | 10:49 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Triangulate
Yes.
They run inside and outside of the car.
You will find a connector that is the pass-thru of the issue.
It’s located behind the rear seat.
It has a triangular flange.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
