fp fuse
Old Jan 27, 2011 | 08:55 AM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
fp fuse
where is the fuse for the fuel pump located.. most of my writing on the fuse box is faded and gone.. i just see fuses...
Old Jan 27, 2011 | 09:34 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cruisin 4 A Fusin
It’s located near the battery.
It’s a bayonet type.
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Old Jan 27, 2011 | 09:37 AM
Axle/Gears: 3.47
Re: Cruisin 4 A Fusin
Happy Racing!
the fuse metal innerds look good but the plastic outer piece is melted alittle... i would assume the fue is good.. yet the relay and pump isnt getting power...?? what gives?
Old Jan 27, 2011 | 10:56 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Sounds like it needs replaced.
Old Jan 27, 2011 | 11:24 AM
NINÅ's Avatar
Transmission: 765R4
Pump Slump
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) see if you have power on pin A of the pump relay (orange wire).
It doesn’t matter what position the key is in.
If there is power there jump pin A to pin E for a second or two with a piece of wire.
Does the pump run when you do that?
Happy Racing!
Old Jan 27, 2011 | 11:47 AM
Axle/Gears: 3.47
Re: Pump Slump
Happy Racing!
pump doesnt turn on at all.. no power to orange wire.. the fuses there are good.. i cant find a fusible link on the orange wire anywhere
Old Jan 27, 2011 | 12:30 PM
NINÅ's Avatar
Transmission: 765R4
Pump Slump
There is no fusible link in line with that orange wire, just the fuse as discussed in post #2.
The
orange wire from the relay goes to a Prime Connector located in the area above the right strut.
It’s just sort of hanging around there and might be difficult to find.
From there the
orange wire goes to the battery thru the fuse discussed earlier, then to a junction block near the right side of the radiator, then to the battery.
Hopefully a PO didn’t change things.
If you still can’t find it you’ll have to open some loom and tape to physically trace it to find the break.
Happy Racing!
Old Jan 27, 2011 | 12:48 PM
Axle/Gears: 3.47
Re: Pump Slump
The
From there the
Happy Racing!
that just confused me completely.. people keep mentioning this junktion block. are u talking about this thing that looks like a crown right next to the radiator tht has about 5 wires connected to it? and what i thought was it goes from the battery to a fusible link then to the fuse then to the relay then to the pump.. ugh im so lost with this its not even funny.. all i know is those 2 fuses are fine. i replaced them anyway and the orange wire isnt getting power, the wire running to the fuse isnt getting power either no wires i see period are getting power... checked all at the relay all the wires at the 2 fuses..
Old Jan 27, 2011 | 12:56 PM
Axle/Gears: 3.47
Re: Pump Slump
ok so i found a black box thing right in between the blower motor and the ac box thing.. looks like a canister n its silver.. its right by the passender strut tower.. it has black orange purple and red wires going to it.. is that the primer?
Old Jan 27, 2011 | 02:21 PM
NINÅ's Avatar
Transmission: 765R4
Pump Slump
Originally Posted by walkthelin3
are u talking about this thing that looks like a crown right next to the radiator…….
Yes.
There are fusible links in that area, however none of them pertain to the pump.
…….the wire running to the fuse isnt getting power…….
If there is no power on either side of the fuse you have found the problem.
The
red wire side of the fuse is supposed to have power on it at all times.
You might have found it.
The Primer Connector has a single
red wire to it.
Happy Racing!
Old Jan 27, 2011 | 02:32 PM
Axle/Gears: 3.47
Re: Pump Slump
Yes.
The
red wire to it.
Happy Racing!
i noticed the car took a dump on me after i cut a black and red wire hoked up to a battery guage that was in the hood... is it possible that that battery guage was wired to run that?
Old Jan 27, 2011 | 02:34 PM
Axle/Gears: 3.47
Re: Pump Slump
well it died like 2 mins after i snipped those wires
Old Jan 27, 2011 | 03:13 PM
NINÅ's Avatar
Transmission: 765R4
Pump Slump
(stalled) after i cut a black and red wire hoked up to a battery guage that was in the hood... is it possible that that battery guage was wired to run that?
If the battery gage was hooked up correctly, just cutting it’s wires wouldn’t cause stalling.
Can you restart it?
Happy Racing!
Old Jan 27, 2011 | 04:09 PM
Axle/Gears: 3.47
Re: Pump Slump
what do you mean?
Old Jan 27, 2011 | 04:56 PM
Axle/Gears: 3.47
Re: Pump Slump
Can you restart it?
Happy Racing!
fixed it.. it was the guage.. i hooked the black and red wires back up and the fuel pump and relay activated... idk why this is.. do those wires just need to be hooked to something in order to work?
Old Jan 28, 2011 | 09:02 AM
NINÅ's Avatar
Transmission: 765R4
Pump Out Of Its’ Slump
Not originally.
Apparently the PO made a change.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
Old Jan 28, 2011 | 09:10 AM
Axle/Gears: 3.47
Re: Pump Out Of Its’ Slump
Not originally.
Happy Racing!
will it work if i put it on the battery instead of the stupid guage i wanna throw out?
Old Jan 28, 2011 | 09:19 AM
NINÅ's Avatar
Transmission: 765R4
Restore & More
Yes, restoring the wiring to the original configuration is the best way for that circuit.
Happy Racing!
Old Jan 28, 2011 | 10:08 AM
Axle/Gears: 3.47
Re: fp fuse
thank you all that tried to help me
Old Jan 28, 2011 | 05:26 PM
squibbles's Avatar
Car: 1985 firebird
Engine: v6
Transmission: turbo auto
Axle/Gears: ?hellifiknow?
Re: fp fuse
can someone send a pic of where its at, the pump fuse because im trying to replace a fuel filter.
Old Jan 28, 2011 | 07:03 PM
Axle/Gears: 3.47
Re: fp fuse
the pujmp fuse is literally in the passenger side area by the battery.it appears as if its in the fender under the hood. its got a black cover over it and its got orange and red wire(s) going to it.il take a pic ofit tomorrow considering its too dark. as for myself.. i just change the fuilter without removing the fuse
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
