picture of fuse box
Old Jan 30, 2011 | 02:08 AM
fonzie85's Avatar
Car: 89 IROCZ
Engine: Forged 347 LS1
Transmission: Built 4L60E with 4k stall
Axle/Gears: 4th gen w/ 3.42 gears
picture of fuse box
I was wondering if any body had a picture of there complete fuse box with all the fuse and every in the correct place. I have an 89 and its missing some things and im not sure what they are. I have looked at the diagrams but thats dosent really tell me what pieces are missing. The thing circled in red below are specifically what im talking about.
Old Jan 30, 2011 | 02:22 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: picture of fuse box
Those are not fuses. They are spots for extra harness' to plug into.
IGN would be for power with the ignition on. Something like a cruise control unit would plug in there for instance.
BAT is a hot all times location.
LPS is power when the light switch is on
Radio, not sure when that would give power or what it would specificaly be for.
Old Jan 30, 2011 | 03:33 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
IIRC, "Radio" is the trigger for the power antenna relay.
Old Jan 30, 2011 | 03:37 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Good answer, good answer...... Survey says!
I might have known that if I went out and looked at mine.
NAH, I would have pulled at it and said "whats this wire doing here"!
Old Jan 30, 2011 | 09:45 AM
fonzie85's Avatar
Car: 89 IROCZ
Thanks guys that helps alot.
Old Jan 30, 2011 | 12:06 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
I just looked at the power antenna schematic. The "Radio" plug is where the power antenna motor gets it's power. It's fused through the "ACC" fuse.
Sorry for the confusion.
Old Jan 31, 2011 | 12:43 AM
Blackhand27's Avatar
Hi, I just joined the site, and I'm not sure if this would be the right thread to ask a question.
I have a 85 Z28, with a 305 engine. Recently the horn stopped working. I think it's the fuse, so I looked under the seat at the fuse box.
Problem is, the letters are so faded on the box, not only can't I tell what type of fuse I should buy, I can't even tell which space is for the horn!
If anybody had any ideas that would be great. Thanks!
Old Jan 31, 2011 | 12:57 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
The horn uses the coutsty fuse. If the interior lights still come on then thats nt the problem.
Carfully pull the horn button off and check the wire. There is a wire on the button and it goes to a plastic sleeve with a spring on it and it twists into the horn ring that is behind the wheel. Lot of times a small ear breaks off the part behind the wheel and it leaves nothing for the wire and sleeve to hook onto to hold it in place.
Also push the button and listen for a click. The horn relay is on the conveniece center under the dash about where your right knee would be while sitting in the car.
Old Jan 31, 2011 | 01:51 AM
Thanks, I removed the button and had a look. Everything appears to be connected.
However, when I pushed the button I didn't hear a click.
When you say interior lights do you mean tha dashboard lights or overhead?
I notcied that the dashboard lights are very dim, ( the speedometer is almost completley out.)
Possible they are connected?
Old Jan 31, 2011 | 02:06 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
The courtesy (saw the the spelling in my last post. I'm all thumbs when I type!) is for the horn, cigar lighter, dome and nay map lights, lights by your feet when you open the door, power antenna, you know the finer things in life.
The instrument fuse would be for dash lights.
That diagram shows fuse locations and the amperage. Not sure if its correct for a 85 though. You might try autozone.com in the repair section. They have had diagrams in the past there.
As for the horn, if any of those other things I mentioned earlier work then your fuse is good. It will send its power to the horn relay and from that the relay gets its ground from the horn button and send power to the horns. They ground by the bolt that holds then to the car.
At the horn relay, if you go to check there, terminal A is hot at all times. Terminal B is the ground when the horn button is pushed and terminal C is the wire that goes to the horns
Old Jan 31, 2011 | 07:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have a 85 Z28, with a 305 engine. Recently the horn stopped working. I think it's the fuse, so I looked under the seat at the fuse box. Problem is, the letters are so faded on the box, not only can't I tell what type of fuse I should buy, I can't even tell which space is for the horn!
Welcome to TGO. The following pic of the fuse box for your 85 should be helpful in the future:
https://www.thirdgen.org/forums/elec...ml#post4350355
JamesC
Old Feb 22, 2011 | 07:09 PM
Thanks so much, the diagram helps a lot.
Old Feb 22, 2011 | 07:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
For anyone else looking for fuse box pics for other years, every 3rd gen year is shown in the wiring diags here: http://www.austinthirdgen.org/index.php?pid=19
Chhose the "body wiring continued" link - fuse panel in upper left corner.
Old Feb 23, 2011 | 03:01 PM
Twentyone's Avatar
Car: 84 Z28 HO & 63 425hp 409 Chev Impla
Engine: 305 HO
Axle/Gears: 3:73
Where da heck is the fuse box(panel) located?(84 Z28)
Old Feb 23, 2011 | 03:03 PM
Car: 1992 RS
Engine: Carbed 350
Under driver side dash.
Old Feb 23, 2011 | 03:05 PM
Twentyone's Avatar
Engine: 305 HO
Axle/Gears: 3:73
Thank you!
Old Mar 25, 2011 | 01:52 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Is there any way to enlarge the diagram of fuse box. I was wondering if there is a fuse for my third tail brake light. Let me know..Thanks
Old Mar 25, 2011 | 09:51 AM
Car: 1992 RS
Engine: Carbed 350
When you choose your car year from the above link, and get the wiring diag, click it, it enlarges.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
chubsworth
Aug 26, 2015 02:34 AM
