82 Cruise Control wth a CFI Engine - Some Info
Old Feb 1, 2011 | 12:12 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
I am posting this information in response to PM from another member regarding this early version of the Cruise Control. This type was only used on the 82 and 83 Camaros and Firebirds.
The pdf contains the schematic wiring diagram and a few other pages from the service manual. These additional pages show the throttle cable connections and routing and some of the control switch functions.
The photos show the throttle cable connections to the rear throttle body. The left cable is from the cruise control vacuum servo located next to the charcoal canister. The cable on the right is from the throttle in the car. The second photo shows some of the cable routing along the front of the block. The third photo shows the cruise control throttle cable support bracket on the front throttle body.
KITT 1983 the approximate throttle cable length from the rear connection point to the servo vacuum is about 38 inches. It is 1o inches from the front support bracket to the connection point, about 11 inches from the support bracket to where the cable begins to pass by the left side exhaust manifold and 17 inches the remainder of the way to the vacuum servo.
I will attach the pdf file with the schematic and the other sheets tomorrow.
Attached Thumbnails 82 Cruise Control wth a CFI Engine - Some Info-dsc01445.jpg   82 Cruise Control wth a CFI Engine - Some Info-dsc01447.jpg   82 Cruise Control wth a CFI Engine - Some Info-dsc01452.jpg
Old Feb 1, 2011 | 03:44 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: 82 Cruise Control wth a CFI Engine - Some Info
thanks for this info
Old Feb 1, 2011 | 12:10 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Thanks, this helps me too!
Old Feb 1, 2011 | 11:08 PM
Here is the wiring diagram and a few pages from the service manual. these are pdf files. Enjoy
File Type: pdf
Old Feb 8, 2011 | 03:57 AM
KITT1983's Avatar
is it completely 100% mehcanical or is any part of the cruisie control run by the computer ?
Old Feb 8, 2011 | 10:03 PM
For all intents and pruposes it is mechanical only for the 82 and 83s. the speed siganl is picked up from the speedo cable that runs through it. The cable from the tranny is the input speed signal and the output speed signal goes to the speedometer on the dash.
The transducer converts the speed signal to a vacuum signal that is sent to the vacuum servo motor and controls the throttle cable to the TI/carb.
All the electric control signals are from the cruise control switch on the turn signal lever.
I think the 84 and newer model years get the speed signal from either the VSS or the ECM.
Old Feb 9, 2011 | 10:13 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
To add to this, 1980s GM cable driven speedometers commonly have a built-in VSS as part of the speedometer. I am not sure whether the 82-83 F-body speedos have it. If they do, the 84-87 cruise should be able to be used in an 82-83 LG4/L69 car.
Old Mar 11, 2011 | 05:09 AM
bigmacnz's Avatar
We need to replace my cruise control stalk.
My autoelectrician removed the old stalk and it has 4 wires but the stalk i gave him had 3 wires.
The circuit diagram shown on this thread has 3 wires.
My car is a 1982 Recaro Transam.
Can we get the 3 wire stalk to work on my car?
Old Mar 11, 2011 | 11:56 PM
A photo of the engine bay, on the front of the left (it may be the right wheel down under) wheel well would be helpful. We need to determine if you still have the cruse control mechanical (82-84?)transducer or the later electronic (84?-92) transducer.
The mechanical transducer uses the three wire stalk. The electronic unit uses the 4 wire stalk. Can your mechanic get a phot of the connector the stalk wires connected to? This is most likely near the base of the steering column.
The mechanical transducer can be identified by a speedo cable from the transmission to the transducer and a second speedo cable from the transducer to the speedometer.
I got your email also but will respond here.
Dave
Old Mar 12, 2011 | 12:56 AM
KITT1983's Avatar
I might upgrade my cruise control to this unit http://www.dakotadigital.com/index.c...prod/prd46.htm
http://www.summitracing.com/parts/DAK-CRS-2000-3/
http://www.restorationperformance.co...h--push/Detail
http://www.streetrodhq.com/detail/18...MOST_POST.html
http://www.dakotadigital.com/index.c...prod/prd57.htm_
http://www.summitracing.com/parts/DAK-SEN-01-1
the stock unit makes me want to hit it with a BFH
Old Mar 12, 2011 | 06:27 AM
bigmacnz's Avatar
I cant get a pic until next week.
I have two 1982 TAs and they both have the mechanical transducer as shown in the pic you uploaded so i know they are factory original.
In one of the cars the cruise control is not going.I removed the stalk and disassembled it a while back.It is also a 4 wire control.The wire colours coming off the terminals were Red,Green,Yellow and Blue
Ive also notice on the info you linked to that it says the push switch at the end of the stalk has 2 positions.Now i dont know if you are supposed to feel that second position as i cant on the switch i removed.
Also both my cars are crossfire.
Old Feb 6, 2014 | 12:47 PM
KITT1983's Avatar
Update I got a HND 6 from Dakota digital. And i am going to sell my 82-83 CFI Cruise control unit. I am going to retrofit my Cruise control.
eightsixseven
Dec 16, 2024 01:50 PM
colton_carlson
Mar 8, 2019 12:21 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
