Power Door Lock problem.
Old Feb 2, 2011 | 04:38 AM
bigmacnz's Avatar
My power door locks will not work with the door key.I suspect the door switch that is activated by the key is faulty.
I would like to know if im on the right track and if someone knows the part number of this switch that must be in the door somewhere??
Fred
Old Feb 2, 2011 | 05:30 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Power Door Lock problem.
There is no such switch. Have to use the buttons.
Old Feb 2, 2011 | 12:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Our cars do not have a electric key switches - the keys just work manually, and only the power lock buttons work the power lock actuators.
Old Feb 2, 2011 | 12:32 PM
bigmacnz's Avatar
Thanks for that.
Old Feb 3, 2011 | 01:07 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Drive German cars mostly???
Got spoiled with the turn the key once and it unlocks drivers door, twice or hold for all doors???
Old Feb 3, 2011 | 09:03 AM
Car: 1992 RS
Engine: Carbed 350
Not just German cars - my 4th gen has that feature.
Old Feb 8, 2011 | 10:41 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
No it doesn't. 4th gen uses the same mechanical lock. You can also use the power lock button, or the key fob. But you can't lock/unlock the doors with the key.
File Type: pdf
Old Feb 9, 2011 | 12:04 PM
Car: 1992 RS
Engine: Carbed 350
Ooops! Your right. Got confused - that was the 1995 Lumina APV we recently had that unlocks like that.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
g.l.mos
Aug 22, 2015 12:02 AM
