Turn Signal Help
Old Feb 10, 2011 | 07:26 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Turn Signal Help
Hey guys, my turn signals blink really fast and I can't figure out why. I've replaced all 4 bulbs, and the fuse under the the dash but it still flashes fast. Any ideas?
Old Feb 10, 2011 | 09:13 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I Think, Therefore I Blink
If the problem started before you replaced the bulbs it might be the blinker went defective, therefore try swapping it for a new one.
If the problem started after you replaced the bulbs it’s because the current draw is different than the previous bulbs.
Happy Racing!
If My Engine Has An Illegal Part, And The Inspector Doesn’t Hear It, Does It Make A Sound?
Old Feb 10, 2011 | 01:43 PM
Car: 1989 Camaro RS
Engine: LH6
Re: I Think, Therefore I Blink
Happy Racing!
It was before. It has done that ever since I've owned the car. So the part inside the steering column is what would be bad?
Old Feb 10, 2011 | 03:31 PM
NINÅ's Avatar
Transmission: 765R4
The part you’re looking for is the turn signal flasher which is clipped onto the fuse panel, as delivered from the factory.
It’s round and approximately 1¼” diameter.
However if it has been replaced it might just be hanging in the maze of wires.
The Fuse Panel is located behind a door which is approximately up and to the left of the brake pedal.
Happy Racing!
Old Feb 10, 2011 | 06:13 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Turn Signal Help
You dont have LEDs in the turn signals, do you?Sometimes that'll increase the flash rate.Ive seen the flasher closer to(but not on) the convenience center.Other times directly on the conv center.Either way the c.c is to the right of the steering column.
You can try swapping the emergency flasher (on the conv center) with the turn signal flasher.See if that fixes the issue, but then the emegency lights will have the fast rate!
Personally i like the faster rate.Makes it more noticeable.
Old Feb 11, 2011 | 06:56 AM
Car: 1989 Camaro RS
Engine: LH6
Happy Racing!
I know where it is. But if that's the problem I'll just leave it, too much of a hassle to get it out.
Nope, no LEDs on the car yet.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
