sending units
Old Feb 20, 2011 | 05:36 PM
fonzie85's Avatar
Car: 89 IROCZ
Engine: Forged 347 LS1
Transmission: Built 4L60E with 4k stall
Axle/Gears: 4th gen w/ 3.42 gears
sending units
This might be a stupid question but I've never bought gauges before... do they generally come with the requiered sending units or do I have to buy those seperately.
Old Feb 20, 2011 | 07:00 PM
mstng5pt0klrz28's Avatar
Car: 1985 Z28
Re: sending units
you talking about aftermarket gauges? (like autometer, sunpro, etc)
Old Feb 21, 2011 | 11:00 AM
fonzie85's Avatar
Car: 89 IROCZ
Re: sending units
yeah i was looking at the Eguus ones to be spacific.
Old Feb 21, 2011 | 12:17 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Spelling Telling
Some Equus gages come with the sender.
It depends which ones you choose.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Old Feb 21, 2011 | 04:46 PM
fonzie85's Avatar
Car: 89 IROCZ
Re: sending units
ok thanks... one more question how much diff. is there between a 2" gauge and a 2 1/16" gauge? The pannel i found to use has holes cut for 2 1/16" gauges and the ones I wanted to use are 2?
Old Feb 22, 2011 | 09:13 AM
NINÅ's Avatar
Transmission: 765R4
Gage Page
The diameter doesn’t mean anything, it’s the quality that matters.
The 2” gages of course will fit into the 2 1/16” holes.
To center them you can build up the diameter with narrow tape, such as pin striping tape.
Then the locking ring can be applied.
Happy Racing!
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
Old Feb 22, 2011 | 11:02 AM
fonzie85's Avatar
Car: 89 IROCZ
Re: sending units
all right thanks... thats what i was thinking but i figured a secound opinion never hurts.
I have yet aother question dose anybody have a wiring diagram for the factory gauges for an 89 iroc (i looked at the diagrams on the autozone site but didn't see one). I was going to try to use the factory wireing and sending units were possible. I assume this would work right?
Old Feb 22, 2011 | 11:36 AM
NINÅ's Avatar
Transmission: 765R4
An EnGAGEing Discussion
Yes to the wiring, maybe to the senders.
But you should be able to tell by the gage response if you have to replace the sender.
Also, you probably won’t need a diagram.
For example, where they supply you with a new temp sender, you simply replace the old sender, and use the same wire that went to it.
On the gage side, you’ll simply need
+, , and the sender wire that went to the old gage.
Happy Racing!
Old Feb 22, 2011 | 12:35 PM
fonzie85's Avatar
Car: 89 IROCZ
Re: sending units
ic that makes sence thanks again you've been a big help
tattmann
Sep 27, 2015 05:20 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
wstephan96
Sep 25, 2015 04:28 PM
6998poncho
Sep 25, 2015 02:56 PM
lanceflame44
Sep 25, 2015 12:28 PM
