a/c compressor clutch plug (where does the black wire go?)
Old Feb 23, 2011 | 05:15 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
86 lg4 carbureted
this plug goes into the air conditioner clutch.
mine is hanging by itself.
I looked at this diagraam and circled where it goes to and it goes to a diode and a high pressure switch apparently... does anyone know where those 2 things are or have a picture of them?
Old Feb 23, 2011 | 05:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: a/c compressor clutch plug (where does the black wire go?)
plugs right into the A/C compressor
Old Feb 23, 2011 | 06:34 PM
0pyders's Avatar
I know where the plug goes, Im trying to figure out where that black wire leads to (the one i'm holding).
Old Feb 23, 2011 | 06:37 PM
Pocket's Avatar
Car: 91 Trans Am
According to the diagram it goes to the AC high pressure switch then ground
Old Feb 23, 2011 | 06:52 PM
0pyders's Avatar
I don't know what an A/C high pressure switch is, is it one of those pieces on the passenger side firewall somewhere?
Old Feb 23, 2011 | 08:03 PM
Pocket's Avatar
Car: 91 Trans Am
Should be the round connector on the rear of the compressor
Old Feb 25, 2011 | 05:13 PM
0pyders's Avatar
I'm just going to ground it. There's no connector on the pressure switch it's just got a black cap over it. Plus there is no wire on the other end.
Old May 11, 2023 | 03:15 PM
Jules Hamel's Avatar
plug goes on compressor between compressor and pully
Old Sep 26, 2023 | 02:07 PM
NathanC's Avatar
do you happen to have a pic of the connector that goes from the engine harness to the ac harness? That connector has a green wire that goes into the connector that joins the 2 harness together. I’m trying to find a picture of where ac compressor connectors go into that ac harnesses since mine were rated by mice.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
Bull86
Aug 10, 2015 05:43 PM
