connecting fans help...plz...
Old Feb 23, 2011 | 11:13 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
ok guys i have an 83 camaro carb...it had mechanical fan and im goin to electric fans...i connected the fans and the computer thats gona b controlling them but i ran into a problem...
i have to connect a wire (its an orange wire from the fan relay) to the ignition wire...i searched it up and it said i have to connect it to a 12volt wire or a power source while the car is on...
can anyone tell me to where i can connect the wire from the fan relay to a 12volt source (ignition wire)...plz help thanks in advance...
if u can post a pic it will help a lot thanks...
i hope this makes since...
Old Feb 24, 2011 | 12:36 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: connecting fans help...plz...
if u can post a pic it will help a lot thanks....
Any of the pink / black wires shown in the 83 circuit diagram
http://www.austinthirdgen.org/mkport...ine_wiring.gif
Old Feb 24, 2011 | 07:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My 85 fuse box had two unused 12volt ignition sources. Check there.
JamesC
Old Feb 24, 2011 | 09:08 AM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks...
JamesC
ok thanks ill look in 2 that...would i able 2 just put a fuse in that?...
Old Feb 24, 2011 | 12:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The source in the fuse box James is referring to has a single slot - a fuse requires 2 slots (fuses have 2 prongs) - so no, you don't put in a fuse - you simply crimp a 1/4in male spade connector onto your wire, and stick it in the slot.
Now - you need to determine if this 12v+ wire you need to connect is 1) the power wire to 'activate' the relay (low amp), or 2) the power wire to run the fans (high amp).
If it's 1, then any 12v+ connection is fine - I wouldn't bother trying to run a wire into the car for it - just find any wire under the hood that has 12v+ when the key is on.
If it's 2, then you definitely do not want to run a wire into the cabin - you need a large guage wire to hold the high amperage draw of the fans (12+ amps), and you don't want to run such a large wire into the car cabin, you want to keep it outside under the hood - so connect to the battery directly (or the power distribution center or the starter).
Now - you stated they want a wire connected to a 12v+ source that is hot-in-run - so I'm pretty sure you just need #1 above - but I wanted you to stop and think about it first to make double sure you're not going to wire incorrectly and cause a melted wire or worse a fire.
Old Feb 25, 2011 | 11:06 PM
Car: 1983 Z-28
Engine: 5.7 L
o ok thanks...i just wanted to make sure...
yes its 1...i need it to activate the relay...i need the 12+ when the key is on...
Bubbajones_ya
Jul 6, 2024 08:32 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
scotrans am
Sep 5, 2015 04:26 AM
