beam light on dash and headlights won't pop up
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
hi guys - parking up today I put my full beams on (with the tell tale light between the indicator lights - 1990 GTA)
Then I couldn't turn it off - really tried to pull the stalk unit back but it just wouldn't go off - so I turned the headlights off - now they won't go back up!??
When I press the headlight switch in the beam tell-tale is there but he headlights do not go up?
Any ideas guys
thanks
Any ideas guys
thanks
Car: 1984 Camaro Z28
Re: beam light on dash and headlights won't pop up
your headlight motor might be gone on your car try using a multimeter to test the headlight motors
Car: 1991 Trans Am
thanks for the input - yeah was geared up to check the headlight motors (though unusual for both to go) and today got in the car - pulled the stalk back and it clicked off the beam and the headlights went up fine???
Will keep a close eye but maybe the beginnings of a bad beam switch
thanks
thanks
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
The angle of the steering column can affect the hi/lo switch. It may need adjusting. Mine only works with the steering wheel tilted up. It's on the list to be fixed.
no problem man
