mistery wire any thoughts?
Old Feb 25, 2011 | 05:03 PM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
So i was taking out the rear interior getting ready to fix the wheel well rot and I found a random wire sitting under the rug and have no idea what its for the wire in question is the orange wire
Attached Thumbnails mistery wire any thoughts?-car-1.jpg   mistery wire any thoughts?-car-2.jpg
Old Feb 25, 2011 | 06:06 PM
Pocket's Avatar
Car: 91 Trans Am
Re: mistery wire any thoughts?
Its not stock, cant help you there
Old Feb 25, 2011 | 06:14 PM
matts86cam's Avatar
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
could have been the power wire for an amp
Old Feb 25, 2011 | 06:19 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Im with matt. Especially seeing the taped splice in the wire behind where the rear seat would be. Also the blue wire which is common for amp remote control.
Old Feb 25, 2011 | 06:27 PM
stealth305's Avatar
Car: 87 Firebird
Engine: 305 w/4bbl 650cfm Holly
Axle/Gears: rear from '68 rs camaro
have you tried tracing it to see where it may lead or end? Running across the floor like like that more than likely its for an aftermarket something or other. Find out if its "hot" then see if its a fused line, you could use this in you favor for just about anything.
Old Feb 26, 2011 | 02:59 AM
well i know the blue wire was an amp wire thats been removed but this one i dunno it looked like it was headed in the direction of the center console and since i wasn't going that far forward i couldn't find the end i was hoping that where it was spliced might have been an indicator but if its not stock then i dunno gonna have to find my multimeter and check for power
Old Mar 1, 2011 | 05:19 PM
camaroflow's Avatar
Old Mar 1, 2011 | 05:55 PM
Originally Posted by camaroflow
hi guys im new here,maybe some can help me here....i bought this 85 iroc it got an 5 speed manual box and a 305 carbed lg4.. the 8th vin nummber is H that should mean its the engine that belongs it the car...now i took the hole car apart for restauration and i found a OBD1 plug..some kind of EFI computer under the dash..whole bunch of plugs that were not connected...so im a little confused i cant imagine GM put all that stuff in there if they not gone use it...any ideas??
i got an idea not to be a d*** but create your own thread in regards to your problem lol
Old Mar 1, 2011 | 07:43 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I'm going with old amp wiring as long as it wasn't connected to anything at the back of the car.
Also for Camaroflo; 1.) Don't hijack other peoples threads 2.) learn how to spell
Old Mar 2, 2011 | 05:02 PM
camaroflow's Avatar
Old Mar 3, 2011 | 06:07 PM
so i was taking my interior to try to freshen it up a bit since i am not doing the interior for another 2 years and i found out this mystery wire went to nothing it was a wire spliced 3 times but went no where lol
Old Mar 3, 2011 | 06:13 PM
stang69's Avatar
Car: 1988 GTA
Axle/Gears: whas an axle and gears
if it orange with black stripe then it coulda have been for cargo light that might have splice for an amp
Old Mar 3, 2011 | 06:43 PM
jharrison5's Avatar
Car: '87 IROC
Looking at the pics you posted I was figuring as much since you can see speaker wire laying next to it. I just finished removing the amp power wire from my IROC and I will give the PO credit he did a hell of a job routing it LOL! It took me the better part of an hour to remove it and I ended up cutting it under the dash just so I wouldn't have to pull all 20 feet of it through the firewall.
Street Lethal
Apr 30, 2019 12:14 PM
Cleotiz
Jan 6, 2018 08:56 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
