Wipers won't stop
Old Mar 5, 2011 | 11:52 PM
ryanlevy02's Avatar
Wipers won't stop
I just bought a 83 Firebird S/E and the wipers wouldn't work when I bought it. I figured it just needed a new motor but on closer inspection, I found that the motor was unplugged. When I plugged it back in, the wipers came on and will not stop running.
Any opinions on what I need to do to fix this problem?
Old Mar 29, 2011 | 05:49 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Rain Pain
It’s the park mechanism or a bad switch.
Disconnect the wiper motor module connectors C1 & C2.
Have the wiper switch in the OFF position.
Have the key in the ACC position.
Measure voltage on C2a.
Measure voltage on C1b.
They need to be zero.
If you have voltage there the switch is bad, or a wire is shorted to a voltage source.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Mar 30, 2011 | 07:11 PM
ryanlevy02's Avatar
Re: Wipers won't stop
thanks, i'll check it out this weekend
wigmobile
Feb 26, 2025 02:56 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
85 Jimmy
Sep 30, 2015 07:56 AM
adelane
Sep 9, 2015 08:51 PM
scottmoyer
Sep 7, 2015 07:06 PM
