MAF sensor?...?
Old Mar 6, 2011 | 06:25 PM
Guest
Guest
Posts: n/a
MAF sensor?...?
Is there a certain spot on the intake that the MAF sensor goes?
Or can it go anyplace on the intake setup? like does it have to go directly infront of the filter or can it go directly infront of the manifold???
Old Mar 6, 2011 | 07:53 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: MAF sensor?...?
You wouldn't have it in front of the filter Where it would get full of crap
Goes between filter and TB
Recall reading somewhere MAF should be within 18" of TB for better response
Old Mar 9, 2011 | 12:22 AM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Re: MAF sensor?...?
what year is your car? 90-92 did not have MAF they had MAP if your car is in these years you dont have MAF and if its not i recommended getting MAP. easier to work with and requires less tuning.
Old Mar 9, 2011 | 06:16 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: MAF sensor?...?
MAP requires MORE tuning if mods done because it does not directly measure actual true airflow like MAF does but calculates it from engine vacuum
Old Mar 9, 2011 | 08:44 AM
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Re: MAF sensor?...?
True. I was speaking from my own experience. Map is easy for me. Not right for everyone
gta892000
Aug 11, 2019 11:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
