vats issue
Old Mar 12, 2011 | 01:23 PM
t-ray10's Avatar
Car: 1992 Camaro RS, 2012 ZL1 on order
Engine: 5.0 305, 6.2 Liter LSA SC
Transmission: T5, TR6060
Axle/Gears: stock, 3.73
vats issue
So I have been dealing with my vats system on my 1992 camaro rs 305 manual. I ran a new key switch but kept the old key hooked up to the vats system underneath the dash so i didn't have to worry about the wires being cut again the the steering column. So I have had this setup for over 6 months and today it decides to go all haywire and the resistance signal is not being completed. What should I use to bypass this stupid system? Any help would be great thanks.
Old Mar 12, 2011 | 02:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: vats issue
Just do the normal VATS bypass with the resistors.
https://www.thirdgen.org/vats_passkey_system
Old Mar 12, 2011 | 08:12 PM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: vats issue
The short version is look for the orange wire running from the wiring harness on the bottom of the steering column and splice a resistor onto it that matches the resistance of the chip on your key.
Old Mar 12, 2011 | 08:17 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: vats issue
He's saying that he left the VATS cylinder with key under the dash, and it's worked for 6 months. I could understand if he was taking the key in and out, but leaving it still shouldn't have worn out the contacts unless they got rusty. Are you getting a no crank or a crank but no fuel? Any codes we can look at?
bbsr72
Sep 27, 2015 05:55 AM
TheTraut88
Sep 11, 2015 05:16 AM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
studebaker60
Sep 7, 2015 12:36 PM
