Speedo doesn't work 91 camaro
Old Mar 24, 2011 | 03:26 PM
wammac's Avatar
Car: 1991 Firebird
Engine: 305 TBI
Axle/Gears: 2.73s
my speedometer doesn't work on my 1991 camaro with an automatic transmission
how do I fix it
Old Mar 29, 2011 | 05:56 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Speed Reading
If your odometer also does not work, it might be the Vehicle Speed Sensor.
Gain access to the buffer which looks like this:
It’s located behind the IP on the right.
Connect an audio amplifier to terminal A
yellow wire to make sure it’s getting a signal.
Ground to ground, the signal wire to terminal A
yellow wire of the VSS.
With the car on jackstands listen for a hum from the amplifier when the rear wheels are rotating.
If you do, then find out if you get a hum from terminal C
tan wire.
The
tan wire then goes to the speedometer unit.
If it gets to the speedometer but the speedometer does not work, have it repaired or replace the unit.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Mar 29, 2011 | 06:01 PM
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
Re: Speedo doesn't work 91 camaro
i have electronic vss and my speedo doesnt work either? ive replaced the sensor in the tailshaft and still nothing????? is there a precedure to test connection? if so can you give a detailed step by step and what tools and what to test?
Old Mar 29, 2011 | 06:05 PM
Car: 1991 z28
Engine: 305 tpi
also my trip meter/odometer arent functioning? bad guage maybe? or is it more likely a bad wire.connection somewhere...ive been told signal goes from sensor to ecm then to guage...where and wat do i test to find the fault?
Old Mar 30, 2011 | 05:54 PM
NINÅ's Avatar
Transmission: 765R4
Speed Reading
Follow the procedure in post #2.
Those are also dependant on the VSS.
Happy Racing!
I’ve NEVER Hit The Wall ! (the safer barrier prevented it)
Old Mar 31, 2011 | 10:57 AM
phil jackson's Avatar
Car: 1989 Iroc Z
Engine: 5.7ci TPI
Axle/Gears: Stock / pos unit
Hello , if it is a 91 and there is a curcit board which slides down in the corner on the bottom you will have to repair the board, I repaired mine and cost me 6 bucks. You also have one for the tach too.
Old Mar 31, 2011 | 11:43 AM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Transmission: 700R 4
Axle/Gears: stock
where is that circuit board located again?, I have the same problem with my 91. I've been told different things except that, could you be more specefic on location so I can go out and check myself. I'm in the process of just getting gauge replacements for under my dash, cause I've got two instrument panels that seem to have the same problems. I'm confused at this point, that's why I decided on just getting replacements.
Old May 21, 2011 | 06:29 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
NINA, the 91 autos and 92 manual speedos are the same right?
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
