Unknown blue wire
Old Mar 26, 2011 | 08:28 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
Unknown blue wire
Hello everyone. Attached is a pic of a blue wire that lost it's connector, and I cannot figure out where it was connected. I have every other wire connected to the proper sensor, but can't figure this one out. Thanks for any help. It's a 84 Trans Am CCqjet automatic.
Old Mar 26, 2011 | 08:37 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Unknown blue wire
I don't have access here at home to wiring diagrams for the 84. The book for my 87 shows a dk blu wire to the knock sensor. Another possibility is the fan temp switch.
Old Mar 27, 2011 | 03:01 PM
84 t/a 5.0's Avatar
I currently have a green one going to the knock sensor. The fan temp switch is on the t-stat housing right? That one has it's wire connected too.
Old Mar 27, 2011 | 03:22 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
That would be the coolant temperature sensor (yellow and black wire). The fan switch is threaded in the passenger side head between the center and rear exhaust ports.
The only light blue (ecm) wire I see is for the mixture control solenoid (on the carb). It should be joined with a pink/blavk wire.
Could be to A/C, blower motor, one of the turn signals (though it looks to heavy a gauge for that) or, it was added in by someone.
Old Mar 27, 2011 | 05:15 PM
84 t/a 5.0's Avatar
Thanks for the help. Now that I think about it, it may be for the knock sensor. Gonna have to check out some of the other sensors.
Old Mar 27, 2011 | 05:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Green wire should go to fan switch in pass side head. Usually blue is knock sensor.
Old Mar 28, 2011 | 02:25 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Does the car have AC? Just remembered seeing light blue to the high pressure switch in the back of the AC compressor.
Old Mar 28, 2011 | 10:47 PM
84 t/a 5.0's Avatar
Thanks for the help guys, It does go to the knock sensor, I put the knock sensor in the spot where the fan switch goes Been a few years since I worked on this project, now it's time to buy a fan switch.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
NBrehm
Aug 25, 2015 11:49 PM
Linson
Aug 21, 2015 02:12 PM
djmarch
Aug 19, 2015 12:07 PM
mustangman65_79
Aug 8, 2015 01:18 AM
