Turn signal problem
Old Apr 15, 2011 | 06:27 PM
redcamaro1988's Avatar
Car: 1988 Chevy Camaro
Engine: 305 TBI
Turn signal problem
I am having the same problem on both my 89 Firebird Formula and my 88 Camaro. The right turn signal does not work on either one. I have changed the bulbs and still nothing. On the 89 Firebird the hazards work and on the 88 Camaro when I engage the hazards neither of the signals work. I am stumped. Any help would be appreciated.
Old Apr 15, 2011 | 10:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Turn signal problem
Turn signals have a seperate flasher unit from hazards - the one c ar might need a new flasher.
Did you check the side marker bulbs as well? They blink with the turn signals, and if either is blown, flasher might not operate.
Old Apr 16, 2011 | 12:52 AM
elpulpo's Avatar
is probably a grounded harness on one of the lights,i had a similar experience and the front was the problem because i lightly bump coming down from my driveway
Old Apr 16, 2011 | 01:18 AM
Engine: 305 TBI
How would I find out if it is the grounding problem?
Old Apr 17, 2011 | 02:15 AM
elpulpo's Avatar
some times is just rust inside where bulb goes and rust cause grounding or false contact so make sure the bulb is good try moving the harness at this time you have to have the signal on,do this to all of the lights related
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
