GTA HID Fog Lights?
Old Apr 17, 2011 | 03:14 AM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
GTA HID Fog Lights?
Hello all, I've got a 89 GTA with what appears to be the original fog lights. I was wondering if any type of HID bulb would fit in there since the housing seems sort of small. If anyone has done this, please let me know what type of bulb you used. Any type of pictures would be great.
Old Apr 17, 2011 | 05:51 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
Re: GTA HID Fog Lights?
yea i would like to now this also
Old Apr 17, 2011 | 07:04 PM
Car: 89 GTA
Engine: 5.7 TPI L98
So come on! Someone enlighten us on this unexplored topic.
Old Apr 17, 2011 | 07:23 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
http://cgi.ebay.com/ebaymotors/H3-Ph...Q5fAccessories
Old Apr 17, 2011 | 07:52 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Isn't it already a HID type light? I mean...It isn't a sealed beam bulb, but is a H1 bulb that slips in from the back of the housing.
Old Apr 17, 2011 | 08:00 PM
Car: 1992 RS 6spd
Thought the fog lights were H3.
Old Apr 17, 2011 | 08:10 PM
Car: GTA
You might be right & my memory is fuzzy. I have several spares, so I haven't had to know it & buy any in quite awhile.
Old Apr 17, 2011 | 08:12 PM
Car: 89 GTA
Engine: 5.7 TPI L98
I've read that they are H3's but I've got my doubts about an HID actually fitting in there.
Old Apr 17, 2011 | 08:28 PM
Car: 1992 RS 6spd
Try looking into H3C H.I.D. kits. C=compact
Old Apr 17, 2011 | 10:42 PM
Car: 89 GTA
Engine: 5.7 TPI L98
That's not a bad idea. I wonder if the wiring on those is any different.
Old Apr 21, 2011 | 04:25 PM
Car: 1992 RS 6spd
If it is, you may have to repin your stock harness. I did that to my low beams on my camaro.
Old Apr 27, 2011 | 08:46 AM
Car: 89 GTA
Engine: 5.7 TPI L98
Well I did some play fitting with an old H1 HID kit I had laying around, and the bulb fit well, but in order to have all the wires accessible you'll have to drill two holes out of the back of the fog light housing to run the wires to the ballast. I'll be buying an actual H3 kit today and we'll see how this turns out. While I'm here, I might as well ask, does anyone have a bracket for the drivers side foglight? Mine is M.I.A.
Old May 16, 2011 | 11:02 PM
Car: 89 GTA
Engine: 5.7 TPI L98
UPDATE: Today I finally got around to tackling this task. I will have pics tomorrow. I was able to fit an H3 HID bulb in each fog light. Although, I had to dremel a small hole on the back of each foglight housing to run the HID wires and the base of the HID bulb out of. Re-sealed it all with some electrical tape and silicone. If you've got basic wiring skills this is fairly simple. I tucked the ballast away in a nice gap underneath the foglight where no water could get to it. Overall, I think this turned out very well and would be glad to help enlighten others on this task.
Old May 16, 2011 | 11:29 PM
Car: 89 GTA
Engine: 5.7 TPI L98
They're 8,000K. A little too blue for some people's tastes. I personally think they look good with my 6,000K headlights.
Old Jun 7, 2011 | 07:11 AM
ice3d's Avatar
Car: 87 Trans Am
Engine: TPI 305
Transmission: TH 700
Wow, what a difference! Can this be used in traffic, or only on open roads where you don't meet any other cars going the opposite direction?
Old Jun 7, 2011 | 09:25 AM
Car: 89 GTA
Engine: 5.7 TPI L98
Technically any time an HID is placed in a non-projector housing, it's illegal. But I've got them aimed properly at the ground so they don't give me or other drivers problems. They really look amazing and give the car a totally different look.
Old Oct 13, 2012 | 09:50 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
I like the look. I am definitely going to have to do this to mine soon.
Old Oct 18, 2012 | 01:43 PM
Car: 89 GTA
Engine: 5.7 TPI L98
I can't believe I haven't uploaded the pictures where both sides have HIDs. lol.
Old Oct 18, 2012 | 01:45 PM
Car: 89 GTA
Engine: 5.7 TPI L98
And of course the headlights....
Above cutoff
Below cutoff
And the magical cutoff
Old Oct 19, 2012 | 05:21 AM
ice3d's Avatar
Car: 87 Trans Am
Engine: TPI 305
Nice! I have just ordered some xenon for my fog ligts/daytime driving lights. What kind of headlights are you running? Do they also work properly with full lights (no cutoff)? And could you show one picture of your headlights in daylight, with the lights off? Looked awesome with that kind of light power and still have the headlights down!
Old Oct 23, 2012 | 01:47 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
how do you have the hids set up in the housing with the pontiac badge still on there. i wanted to do something similar where i make new headlight mouldings and hide the projector behind it so it looks stock but when i turn on the lights it will just shine light through the plastic... only problem is i want my badge to stay haha
Old May 11, 2013 | 04:48 PM
AssaulT/A's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.08? unlimited slip
I know this is an old-ish thread, but i tried this and the H3 bulbs i got were too long, by about half an inch. Did you have to get the compact bulbs or were you able to get the regular ones to fit?
Old May 12, 2013 | 10:38 PM
Car: 89 GTA
Engine: 5.7 TPI L98
I fixed that by bending the shield inside of the fog lamp housings upwards so the bulb would clearance it. I was able to use standard H3 HID bulbs in that housing after bending the shield without any sort of problem.
I'm installing some 3000K yellow HIDs later this week in the housing and if I remember to take pictures I should have a slightly more detailed write up than before. Haha.
Old May 12, 2013 | 10:43 PM
Car: GTA
Take the shield out completely & it'll help even on stock bulbs.
http://www.austinthirdgen.org/index.php?pid=25
Old May 13, 2013 | 04:31 PM
AssaulT/A's Avatar
Car: 1986 Trans Am
I must not have the original foglights then, because i dont have one of those. I had a lens, the silver reflector, and the black housing that i still cant get out of the car. It's hinged on the bottom and i cant figure out how to remove it.
Old May 23, 2013 | 08:35 PM
Car: 89 GTA
Engine: 5.7 TPI L98
My infatuation with lights continues
Old May 23, 2013 | 09:58 PM
akanitro's Avatar
Just received my H3 5000 HID setup and modified the new fog light lenses. Putting them in this weekend since the car is going back together from paint soon. Pics to follow soon.
Old May 24, 2013 | 01:13 AM
Car: 89 GTA
Engine: 5.7 TPI L98
Awesome! Feel free to put the pics here. I'd really like to see. Oh and thanks again for the rims. Still got the car wearing em proudly lol.
Old May 24, 2013 | 12:37 PM
akanitro's Avatar
The wheels look great on the car. I am doing the install tomorrow morning. Pics will look like crap as the car is in a hundred pieces getting ready to start spraying the new paint next week but I will post them up anyway. Just curious about drilling the holes in the rear
of the housing for the install. I know I need to drill the holes for the wiring but do I also need to drill a hole for the back of the bulb so it doesn't contact the housing? I am sure I will find out tomorrow, just looking for some insight for preparation.
Old Jul 23, 2018 | 10:49 AM
Ramrod I's Avatar
Car: 1987 GTA
Engine: 5.7 TPI
Axle/Gears: 9 Bolt Borg Warner 3.73 Gears
Old Sep 2, 2019 | 08:46 PM
ZOOCREWRACING's Avatar
Car: 91 GTA
Engine: 5.7 ,ALUM CORVETE HEADS
Transmission: 700R
Anybody have any updates on this subject?
I'm trying to replace the driving light bulbs in a 91 Firebired/GTA, and install LED's? from SuperBrightLED.com, There a little longer and there's a defelector sheild in the lens that needs to be removed.
Old Sep 2, 2019 | 09:07 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I put an LED in my fog lights in my 91
Old Sep 2, 2019 | 09:12 PM
Car: 91 GTA
Transmission: 700R
did you have to remove the shield inside the lamp?
Old Sep 2, 2019 | 09:20 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I don't remember if I had to or not, but I did since the lenses adhesive had failed and they just came right off when I removed them from the housings. I didn't want the little rectangle in the way of the lighting. They are very bright and kind of blind people when I have them on at night even though they are pointed downwards-ish
Old Sep 3, 2019 | 07:37 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
The little rectangle is what keeps the light pointed downward, the cut off line. No matter how far down you point the lights it will reflect it upwards and you will blind oncoming traffic. If the superbrights the OP talked about are made by Luyed, they make different versions that are shorter and should work with the reflector still in place.
Old Sep 3, 2019 | 08:39 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
With the old halogen there was no cut off. I believe the block was installed per federal guidelines so you were not seeing light directly out of the bulb but only reflected light.
I only mentioned them being pointed down because one of the other posters says that theirs don't blind people, but that is definitely false
Old Jan 16, 2020 | 09:13 PM
Allan Burns's Avatar
Attachment 360073
Attachment 360074
Attachment 360075
Attachment 360076
Dude that looks amazing I want to convert all my lights on my gta to led. I think it gives the car a much more refined look. More dignified. Modern.
Pro
Sep 29, 2017 04:18 PM
lonesomeloser
Jun 17, 2010 05:57 PM
90BlackGTA
Exterior Parts Wanted
Feb 27, 2010 01:50 PM
turismo
Apr 8, 2003 10:08 PM
