Need console clock wiring help and harness
Old Apr 18, 2011 | 09:57 PM
ms87iroc's Avatar
Car: white 87 iroc-z
Engine: 5.7 tpi
Axle/Gears: 3:27
I am installing a console clock in my 87 iroc and i do not have the female (3) prong plug in wiring harness for clock, so i am not sure what prong on clock is ground, constant hot and dimmer. I am going to borrow power from my radio for the install. I want to test the clock but i am afraid to try without knowing correct placement of wires on clock, i dont want to short something out and ruin the clock. Maybe this was already discussed in earlier threads, if so, can you direct me to it. Also i need the female plug in if anyone knows were i could find one. Thanks
Old Apr 19, 2011 | 08:33 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Need console clock wiring help and harness
You won't hurt it - that's how I found what was what on my clock. I just tested all the possibilities until I found what was ground, and which was illumination. 4 years later my clock still running strong.
Old Apr 19, 2011 | 10:15 AM
my82roc's Avatar
Car: 89 Iroc Convertible
I have a whole bag of console clock harness pigtails if you need it
Old Apr 19, 2011 | 05:07 PM
ms87iroc's Avatar
Engine: 5.7 tpi
Axle/Gears: 3:27
Thanks guys for the info, and sure i would like to get one of those clock harness pigtails from you, how much and were do i send. Thanks
Old Apr 19, 2011 | 05:12 PM
Car: 1992 RS
Engine: Carbed 350
I just used standard 1/4inch female spade connectors on my wires.
Old Apr 19, 2011 | 05:23 PM
my82roc's Avatar
PM Sent
Old Apr 19, 2011 | 06:46 PM
ms87iroc's Avatar
Engine: 5.7 tpi
Axle/Gears: 3:27
pm sent
Old Apr 19, 2011 | 08:13 PM
Car: 1992 RS
Engine: Carbed 350
There's a pic of my clock mounted in this thread: https://www.thirdgen.org/forums/inte...ggestions.html
I didn't want it in the center console b/c I wanted a cup holder there.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Aug 21, 2015 01:54 AM
