90 TA Headlight Wiring Issues
Car: 1990 Trans Am
Engine: 5.7 TPI with goodies
Transmission: Autotragic
Just got a 90 TA and I am doing the usual repairs. Just fixed the passenger headlight motor, but it is not receiving any power. I took the headlight motor and connected it to the driver side and it works fine. I tried searching and only found old threads with pictures that are not there anymore. I am assuming it has something to with a wiring harness or a fuse. If someone could shed some light on this for me and possibly include some pictures of where this harness is I would appreciate it.
Car: 1990 Trans Am
Re: 90 TA Headlight Wiring Issues
I found the module, and I tore it apart and I couldn't see an issue with it. Does anyone have a DIY on how to repair the module? Or possibly a reliable place to purchase one that is not a dealer. How bad would it be to just bridge the motors together. Like run wires from the driver sides motors connector to the passenger side.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
☼ ☼ Bridge Over Troubled Lights ☼ ☼
You can bridge the left and right headlight doors however use a relay because you will be exceeding the intended current value of the module channel.
Happy Racing!
Don’t Ask Me Why I Don’t Get Dizzy After Going In 400 Circles
Happy Racing!
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
