High Beams Not Working!
Old May 5, 2011 | 07:13 PM
ZWis212's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
I bought my 1990 camaro about 2 weeks ago and my high beams worked a couple of times. But now when i go to turn them on when i pull the lever back it wont click to turn them on. It just goes back with out anything happening. Not sure what to do. Any help is appreciated! Thanks!
Old May 5, 2011 | 07:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: High Beams Not Working!
Adjust the high beam switch - it's on the steering column just above the brake pedal. Remove the underdash panel, move the lever and you'll see a rod moving up/down the column into the switch. Two 7mm screws hold it on. Set your tilt wheel where you normally drive, lossen the two screws, and slide the switch up the column just a tad, retighten and try it - adjust as needed, but make sure the tilt wheel is down where you have it when you drive - it's impossible for the high beam switch to work at all positions of the tilt wheel.
Old May 5, 2011 | 10:11 PM
ZWis212's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Thank You ill have to try it tomorrow. Very much appreciated!
Old Jul 1, 2011 | 06:31 PM
Extreme305's Avatar
Car: 1991 camaro RS
Transmission: manual
Axle/Gears: regular
CamaroNewbie,
I am having the same problem where i pull back the turn signal lever and nothing happens. I found the white switch under the dash where the steel rod goes. And i push it in and it works. But my problem is, is that i have no idea where the rod connects to to the turn signal lever? I see how the rod goes into the white box under the dash, but how does it stay there? it just goes in and out and than where does the rod connect too on the turn signal lever? Can you or anyone please help me out with this one, its been bothering me for days.
Old Jul 1, 2011 | 06:41 PM
Car: 1992 RS
Engine: Carbed 350
I'm not sure either - if the rod is in place and moving, no need to really know. Trust that it works, and adjust the switch accordingly so that the rod activates the switch.
Old Jul 1, 2011 | 06:50 PM
Extreme305's Avatar
Car: 1991 camaro RS
Axle/Gears: regular
Does anyone else know how the high beam steel rod connects to the turn signal lever?? I can connect it to the white switch but i dont know where it connects to the turn signal lever? Anyone please help me, im loosing my mind over this.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fronzizzle
Aug 19, 2015 01:36 PM
jackhammer
Aug 15, 2015 10:04 PM
BBSDesigns
Aug 11, 2015 07:39 PM
