Spare key replace???
Old May 9, 2011 | 01:07 PM
fredbear's Avatar
Car: 1989 IROC-Z
lost my spare key...1989 camaro with the chip on key where can i get a replacement?
Old May 9, 2011 | 02:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Spare key replace???
Any ACE Hardware store - about $25.
Old May 9, 2011 | 07:32 PM
fredbear's Avatar
Car: 1989 IROC-Z
really its that easy???? what about the chip in the key. I know you can get your keys dublicated and all but doesnt the chip in the key need to match up with the car and all other wise whats the point of it.
again I dont know Im not argueeing the fact just asking questioons cause I dont know
Old May 9, 2011 | 09:14 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
They have a machine. They put the key in. It reads the resistance. Thier are certain #'s for the chips. They look up the key #, pull out the key. Cut it to fit and your set to go. Your local dealer can do this too for about 30 dollars.
Old May 9, 2011 | 09:19 PM
grassyflats's Avatar
just dont go to the dealer
Old May 10, 2011 | 11:51 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
GM used those chiped keys an ALOT of cars, so they arent hard to find. Pretty much any place that cuts keys will have a key blank for a GM chipped key. Not all of them will have the machine to read the chip resistance though. But you can do that yourself with a multimeter.
Old Jul 19, 2012 | 04:04 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
When I went to Ace they said they didn't have any blanks that even came close. I had my VATS disabled so it didn't matter what the resistance was, but they still couldn't make one. I do have a spare key that I got when the switch was replaced after some idiot tried to steal my car by hammering a screwdriver in the switch so that the key wouldn't fit any longer. the spare key doesn't have a resistor so I can keep it in my wallet.
Old Jul 19, 2012 | 08:17 AM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
They have VATS and non-VATS GM key on ebay. IF your VATS is disabled, you may be able to use the regular key which is cheaper.
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
