Huge Problem! Please help!
Old May 23, 2011 | 05:47 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Hi Guys,
I drove my Firebird to a shop today and it ran just fine. I went to leave and the engine wouldn't start. It turned over a little once or twice and then wouldn't turn over anymore. The shop guys came out and put a charger on it and it finally started.
However, on the way home, the tach was about 1000rpm too high and would bounce around. Then the SES light would intermittently come on and the car would surge until it went off.
I had the computer hanging from under the dash resting on the floor board. I kept hearing a static-sounding whine noise when I would hit the gas coming from the computer area. When I got home, I parked it and the computer was very warm to the touch. And now it won't start or turn over again! If I turn the key forward, I hear a static-like noise and all the dash lights are extremely dim. I even tried unplugging the computer completely but the same thing happens!
Anyone have any ideas what would all of a sudden cause this???
FYI - I checked all the fuses in the fuse panel and they're good.
Thanks!
Old May 24, 2011 | 04:01 PM
Re: Huge Problem! Please help!
I guess I've stumped the guru's
Old May 24, 2011 | 06:27 PM
I started looking for any burnt or disconnected wires today but couldn't find anything.
I then hooked the ECU back up and put the factory PROM in it. The car then started up!?!
However, the check engine light was on the whole time and my scanner won't connect to the ECU. Also, I tried to manually jumper the ALDL port to get the flashing codes and that didn't work either.
Confusing!?! So now I'm worried about driving it because I don't know if it will just decide to not start from now on. Can anyone recommend anything to check/replace? Switches, relays?
Old Sep 17, 2012 | 03:58 PM
amyz28's Avatar
any luck here my prob sound similar
hey i was wondering if u cud help, my ses light goes goes crazy whilst during a normal start up AND when connecting A and B in ALDL port and as lights flickering (as tho theres a bad wire)the engine drops revs, does this mean its ecm problem or electrical, my car 86 iroc TPI 5.0 has been 'broke' for 1 WHOLE YEAR NOW and its killin me im over in scotland and no want wants to work on her plz help heres a vid
p.s ive changes plugs, leads, 02 sensor, coolant temp sensor and thermostat, new battery.car ran perfect till it was out for a hard drive (which wasnt common) my gut feeling is its electrical i cant get any codes
this second vid is with the A AND B bridged, it wont read a code
http://www.youtube.com/watch?v=InNYu...3&feature=plcp
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
