how can i fix highmount stop light (trunk)
Old Jun 9, 2011 | 01:36 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
on my 86 iroc i have the high mount stop light, it has bulbs in it, but no wiring. being a neon green thirdgen, more the reason to get pulled over by them coppers. any help on how it works, or how to fix it would be much much appreciated. or list of items i need in order to fix them.
Old Jun 9, 2011 | 01:55 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Re: how can i fix highmount stop light (trunk)
No wires humm is it stock 2 car you can always splice into the back brake lights and run the wires
Old Jun 9, 2011 | 01:57 AM
jeff_blake's Avatar
yeah, was like that when i got it, he runs now, just needs highmount to work, and idk what the previous owner did, but theres no wires. nothing else i could splice em.
Old Jun 9, 2011 | 02:43 AM
jeff_blake's Avatar
where can i find the 'plugs' if i wanted to do the highmount delete?
Old Jun 9, 2011 | 03:12 AM
camaroinoh's Avatar
Car: 84 z28
Um plugs??? might be me but can u explain alil
Old Jun 9, 2011 | 03:41 AM
jeff_blake's Avatar
thinking of just taking it off, personally dont mind either way. did a bit of searching around, there hatch bolts u use in place of the highmount. well see.
Old Jun 9, 2011 | 10:12 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Theres should be an arm towards the middle of the hatch when you open in and IIRC ive been told that is for the light, gets power when the hatch is closed, mines missing so I ran wires
Old Jun 9, 2011 | 10:29 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
yeah the wires on the passenger side hatch shock thing, the gas shock, its like a little boot
Old Jun 9, 2011 | 02:48 PM
jeff_blake's Avatar
did u run them from the brake switch or splice in?
Old Jun 9, 2011 | 02:56 PM
Engine: L31 350
came like that factory bub.
Old Jun 9, 2011 | 03:00 PM
jeff_blake's Avatar
oh I know dude, meant blufbdy. I would like it factory but guy I got it from had no wires back there
Old Jun 9, 2011 | 03:04 PM
Engine: L31 350
are you sure he didnt tuck them under the passenger panel?
Old Jun 9, 2011 | 03:13 PM
jeff_blake's Avatar
yeah when I first got it I stripped it down nothing hiding there
Old Jun 9, 2011 | 03:25 PM
Engine: L31 350
thats weird... wonder why someone would cut that wire..
Old Jun 10, 2011 | 08:05 PM
jeff_blake's Avatar
this whole car was weird. looks like he had it a track car, banged up the rear. fixed it and swapped everything back to be honest. it's been a fun little project. trying to get it on the road within the week now
Wade787b
Sep 29, 2015 01:15 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
dyeager535
Aug 28, 2015 08:10 AM
Jae992
Aug 27, 2015 09:07 AM
Omega
Aug 10, 2015 12:46 PM
