Need Help With Check Engine Light
Old Jun 11, 2011 | 02:01 PM
cruuzr's Avatar
Hey guys, new here. I recently purchased an 85 K5 Blazer, which one of the previous owners swapped a tpi into. From what I can tell, it is either an '87 or an '89. I need to check the ecm for trouble codes, but I don't have a check engine light (either not hooked up, or its burned out). How would I go about wiring a light in, or can I temporarily use a test light instead? Any help would be greatly appreciated.
Old Jun 11, 2011 | 02:20 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Need Help With Check Engine Light
theres a way to use a test light...ive seen the wiring diagram posted in a thread for something, but i cant for the life of me remember were. but atleast you know it can be done ....and WELCOME TO TGO!!
Old Jun 11, 2011 | 02:30 PM
cruuzr's Avatar
Cool, at least its possible. I went ahead and bought a red led while I was out, so I can hook it up as the cel when i figure it out. I've seen everything from the cel being pin D on the aldl to ground pin 12 to pin 6. I don't want to go grounding anything on the aldl, without knowing what it is first, ya know?
Old Jun 11, 2011 | 03:12 PM
travis401's Avatar
Car: 91 Camaro RS
yea, from what i rembmer you wire the light to pins on the aldl and when you do the paperclip trick to get the store codes it flashes the wired light just like it would the SES light. im gonna try and find the thread with that diagram in it.
Old Jun 11, 2011 | 06:04 PM
cruuzr's Avatar
I certainly appreciate it.
Old Jun 11, 2011 | 06:15 PM
travis401's Avatar
Car: 91 Camaro RS
FOUND IT!!!!
https://www.thirdgen.org/forums/tech...ats-wrong.html
post #44
Old Jun 11, 2011 | 06:22 PM
cruuzr's Avatar
That's exactly what I was afraid of seeing. My pin D is empty. Dangit!!
Old Jun 11, 2011 | 06:50 PM
travis401's Avatar
Car: 91 Camaro RS
yea if theres no pin there, its kinda hard to use it
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
