turn signal problem
Old Jun 18, 2011 | 12:17 AM
86Zguy's Avatar
Car: 1986 IROC-Z, 1984 C10
Engine: 5.0 305 V8
Transmission: 700R4 Auto
turn signal problem
so recently my right front turn signal wasnt working when it was on running lights, the blinker worked fine, so i went to autozone and got a new bulbs for it thinking that just one of the filiments was broken, and installed both of them now i have no front turn signal and the left indicator on the dash stays on also the rear doesnt blink any ideas on the issue? i dont have the slightest clu whats wrong maybe a short? im gunna check the fuses tomorrow and see if i blew one
thanks in advance
Old Jun 18, 2011 | 06:04 AM
cHEVy hEAVy's Avatar
Car: 1989 IROC Z
Engine: 5.0 tpi. stock [for now]
Re: turn signal problem
i had a similar problem, and realized it was just the way i put the bulb in
do the new bulbs come on if the running lights are on?
if they do, try taking the bulb out and putting it back in but turn the bulb before you put it in so the -,+ ends on the bulb are opposite of how you put it in the first time.
do you unerstand what im trying to say? im having a hard time trying to put it into words. if not, ill try to explain better
and if it isent the bulb, it might be the flasher. if you need a pic of it, ill take one.
Old Jun 18, 2011 | 06:11 AM
Car: 1989 IROC Z
also forgot to ask, if they do come on, are they Bright? or is One brighter than the other? if so, this points to the bulb. thats what i noticed on mine, i put new ones in and than my dash light stayed on (right turn sig. light) and it wouldnt flash, so when i got on the outside of the car i noticed the right bulb was wayy brighter than the other. so i took out the bulb & turned it, put it back in, and they were all good.
Old Jun 18, 2011 | 10:15 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
it sounds like a problem i had play with the wires goin into the bulb socket. one may have a loose connection cause mine was off then dim every now and then
Old Jun 19, 2011 | 05:55 PM
86Zguy's Avatar
Engine: 5.0 305 V8
i took the bulbs out and reinstalled them turns out i forgot to turn them in the socket but now im back where i started befor the issue the running light on the right doesnt stay on but the turn signal works so i think a wire is just loose or the housing is corroded
Old Jun 19, 2011 | 06:03 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Sounds like a poor ground connection in the socket.
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
