Temp Gauge Reading High
Old Jun 26, 2011 | 03:34 AM
willk's Avatar
Car: 1989 Camaro RS
Engine: 2.8L
Hi guys, looking for a bit of help here. I recently swapped out my stock '84 cluster with non-functioning "idiot lights" (and a mess of aftermarket gauges) for one that has self-contained gauges and everything's been fine except I'm having issues with the temp gauge reading way too hot.
The sending units were replaced as needed. Used a WT359 temp sender.
The ohm readings of the sending unit reads 1600 while the engine is cool (which I've read is normal), at least until it is connected to the green sending wire. It then drops to around 1100. Pulling the gauge out of the cluster (with the wire still attached to the sending unit) brings the ohm reading back to normal. The gauge needle tends to creep up while disconnected and when the key is off, usually only stopping when it finally pegs. It all leads me to believe that the gauge is shot, but I'd like to hear the opinions of some of the Camaro gurus here.
Many thanks!
Old Jun 26, 2011 | 01:24 PM
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
Re: Temp Gauge Reading High
I have an 86 IROC and 3 temp gauges later, none of them have never been accurate. I have a radiator cap that reads the temp and it never reads above 180 but the gauge always creeps up to just a little past the red line. I dont trust those gauges.
Old Jun 26, 2011 | 03:21 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
stock gauges are notoriously inaccurate....
Old Jun 26, 2011 | 09:05 PM
willk's Avatar
Car: 1989 Camaro RS
Engine: 2.8L
@1986tpiiroc: That's essentially what mine is doing. My thermostat kicks in at 180, and by that time, the gauge is already reading well above 260. Then it just kinda hovers over the first red marking while driving down the road.
@travis401: Yes, I'm well aware from previous searches that the stock gauges have a reputation for being prone to failure and inaccurate calibration, however, I'm simply asking if my observations are indicative of a failing gauge or if it could be the sending unit.
Old Jun 27, 2011 | 12:17 AM
travis401's Avatar
Car: 91 Camaro RS
i was just stating the gauge could not be failing and the sending unit could be perfectly fine, the gauge could just be reading out the wrong temps. you can try a new temp sender or a "new" gauge
Old Jun 29, 2011 | 04:15 AM
willk's Avatar
Car: 1989 Camaro RS
Engine: 2.8L
But that's not what you said. Thanks for the elaboration, though. Sorry if the tone of my reply seemed a little harsh. It's just that I have done a lot of searching on this topic and each question about these things had posts with people stating *all* of the stock gauges are "trim pieces!" and "notorious for being inaccurate" before telling the original poster to just buy aftermarket gauges.
Well, all I can say to that is my "new" stock gauges are reading almost exactly what the aftermarket gauges read before the cluster swap, except for the temp gauge, of course. So to me, an answer like that ignores what could be the source of the problem.
There are a couple things I noticed recently though, which is making me wonder if my problem is somewhere in the cluster itself. Turning the key off after the engine has warmed up (gauge reading ~260) and then turning the ignition back on brings the needle about to where it should be (a little below the 220 mark). After starting the engine back up, it slowly rises to 260 again. And I noticed it will fluctuate pretty in tune with battery/alt load. High/low beams, climate control and engine fan, rear defogger, and the cluster backlights all seem to influence it. It's not a huge difference, but it's the only gauge (other than the volt meter) that seems affected.
I'll tear into the cluster with a volt meter within the next couple days. If anyone can tell me what kinds of voltages to expect at the three gauge contacts (with ignition on/off, engine running) for comparisons, I'd really appreciate it.
Old Jul 5, 2011 | 07:26 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
You can test the gage.
You’ll need a 2K potentiometer, an ohmmeter, to make it more convenient add a large ****, and a piece of sheet metal to mount the potentiometer.
After mounting the potentiometer and installing the ****, use the ohmmeter to adjust the potentiometer to read 1370Ω.
Mark the spot on the sheet metal at that point.
Now adjust the potentiometer to 55Ω and mark the spot on the sheet metal at that point.
Now wire the end you had the ohmmeter connected to, to vehicle ground.
At the engine, disconnect the wire that goes to the sensor.
Wire the wiper of the potentiometer to the wire you just disconnected.
Have these test leads long enuff so you can operate the tester from the cockpit.
Turn the key to RUN.
Set the potentiometer to 1370Ω and observe the gage.
Does it make it’s way to 100°?
Slowly sweep the potentiometer to 55Ω and observe the gage.
Does the gage progress from 100° to 260°?
Happy Racing!
Don’t Ask Me Why I Don’t Get Dizzy After Going In 400 Circles
Old Jul 7, 2011 | 04:56 AM
willk's Avatar
Car: 1989 Camaro RS
Engine: 2.8L
Re: Gage Rage
Hi NINA, thanks for the response. Just curious, could I accomplish the same process you describe using plain resistors? I've got plenty of them lying around; I think all I'd need is some sort of ohm -> temperature reference.
Old Jul 7, 2011 | 08:23 AM
NINÅ's Avatar
Transmission: 765R4
Gage Rage
Absolutely willk.
As far as the temperature to resistance reference, you can use the same numbers as in post #7.
You probably won’t have a 55Ω or 1370Ω one in your collection however you might have a 56Ω and 1300Ω so use those.
If you don’t have those you can connect some together to render those values.
I don’t have any more Ω -° references than the two in post #7.
Happy Racing!
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
Old Jul 13, 2011 | 04:44 AM
willk's Avatar
Car: 1989 Camaro RS
Engine: 2.8L
Alright, I finally got a chance to test the gauge with some resistors. Values seem relatively close to what they should be. At 1200Ω, the gauge read just off the 100 line and at 56Ω, it read slightly higher than 260 (close to where the needle hovers while driving down the road). And I just found a nice little chart with ohms -> temp reference points (here). Will try a few more values later today to see how accurate it is with middle values, but now I'm starting to think the sender is either bad or not the right one for this gauge. Just can't help but wonder which one to get when there are so many different models that are supposedly made for gauge use... If anyone is willing to give out suggestions for senders that have proper range for a factory 100-260 sweep gauge, please do let me know.
Ghettobird52
Jul 5, 2024 11:18 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
