relay/plug ID
Old Jul 8, 2011 | 04:35 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
relay/plug ID
http://m1205.photobucket.com/albumvi...BZ0CKJFB9LM%3D
i need help determining what a few plugs and relays are
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: relay/plug ID
Old Jul 8, 2011 | 04:36 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: relay/plug ID
Old Jul 8, 2011 | 04:39 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: relay/plug ID
Old Jul 8, 2011 | 04:40 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: relay/plug ID
Old Jul 8, 2011 | 04:49 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: relay/plug ID
Numbers and locations of relays
10032973- Located by blower motor
14084351 - Located by battary
BLH 882621 - Located by the brake cylinder
14078915 - Located nexed to Blh 882621
Old Jul 8, 2011 | 04:50 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: relay/plug ID
Old Jul 8, 2011 | 06:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: relay/plug ID
I think that this one is the electronic spark module, and not a relay.
Old Jul 8, 2011 | 06:14 PM
Car: 1992 RS
Engine: Carbed 350
Re: relay/plug ID
Use wiring diags and check the wire colors: http://www.austinthirdgen.org/index.php?pid=19.
Your photos are very small and hard to see.
Underhood, relays include:
fuel pump relay
fan relay(s)
I think MAF has a relay
Sorry - all I can think of at the moment.
Old Jul 8, 2011 | 06:40 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: relay/plug ID
i just pulled electroni spark module. I prob can pull out fan and fuel pump relay also
Old Jul 8, 2011 | 06:57 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: relay/plug ID
So I look at diagram and determined that the two I didn't know were fan and fuel pump. Being I am using mech pump, can fuel pump relay and wires come out. Fan , as of moment I have to plug it directly into fusebox. Can I just cut fan wires out of ecm, and then try and run it a different way??
Old Jul 8, 2011 | 10:29 PM
Pocket's Avatar
Car: 91 Trans Am
Re: relay/plug ID
Get better pictures with descriptions of wire colors. The only obvious one is the ESC module as newbie pointed out
On the otherhand, it seems like you're doing a carb conversion. Why not remove everything and put back only whats needed?
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Old Jul 8, 2011 | 10:45 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: relay/plug ID
I am to the point now where I just want to confirm that I can cut out fuel pump/fan relay and wires. Also I have a wire from the opsu that hooks into enm bundle. Can I cut that also. And lastly if all those are good to cut, all I will be left with is a purple/violet wire that I don't know what it is or where it goes
