Need Help with Accessory Power
Old Jul 10, 2011 | 08:47 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
alot of my components like the fuel pump, electric fan, radio, etc i currently have wired to a toggle switch because i kept having trouble with the stock wiring.
Before i put the switch in it was either hit or miss with the electronics. If the car started it would run all day but sometimes after turning it off these comonents would not come back on again.
Im saying screw it to the stock wiring and fuses and relays.
I need the best source for accessory power. Like the first click of the key need to turn on my radio. The next click should turn on my fuel pump, electric fan, and ignition. Where is the most reliable place to get that power from?
i plan on just running a wire off that with a new fuse to these components.
Any help is appreciated.
Old Aug 22, 2011 | 05:19 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
Re: Need Help with Accessory Power
bump
Old Aug 22, 2011 | 06:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
In the fuse panel, there are single slots that are open - I say single because a fuse has 2 legs and thus won't plug into these slots.
They are marked:
BAT - 12v+ always, regardless of the key
IGN - 12v+ only when key is ON
RADIO - 12v+ when key is ON, or when key is in ACC position
LPS - 12v+ only when lights are on
That should help you. They accept a standard 1/4 inch male spade terminal - just crimp one on a wire, plug it into the slot, and add inline fuse
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
