Alternator Wiring
Old Jul 12, 2011 | 03:18 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Alternator Wiring
Hey guys.
Awhile back, the POS reman alternator that was in my car when I bought it finally gave out. I bought a nice chromed out 140 amp powermaster alternator. HOWEVER...
I was told since this alternator was a 1 wire design, all I needed was the positive cable going to the battery and I could leave the 2 wire red/white harness that went to my old alternator unplugged. This alternator had what I thought be a blockoff plug where the harness would have gone on a different model using the same casing. But then, the "blockoff plug" fell out with normal engine operation. I wasn't a plug. This alternator actually has the two prongs for the harness that I left unhooked. The car seems to run fine as well as the charging system, but I was wondering what am I leaving out by not having this harness hooked up to the alternator?
Old Jul 12, 2011 | 05:45 AM
willk's Avatar
Car: 1989 Camaro RS
Engine: 2.8L
Re: Alternator Wiring
Sounds like you have one of Powermaster's 'hybrid' alternators that can be installed as one-wire or three-wire. Using it as a one-wire setup, you don't take advantage of the alternator's ability to energize with ignition, sense voltage remotely (for regulation at the primary junction), and work with the warning light in your dash (if you have one).
I actually just wired up my own hybrid Powermaster alternator (I've got the 100amp model) to a three-wire setup and it definitely improved voltage stability, especially at night when the headlights are on. So if you've already got the proper harness for hooking it up as a three-wire alternator, I'd recommend going for it.
For further reading, check out this article, very useful information here: http://www.madelectrical.com/electri...hreewire.shtml
Old Jul 12, 2011 | 09:40 PM
Car: 1985 Z28
I still have the brown wire tucked up in some wire loom, but I can't seem to locate the red wire or remember what I did with it. If I have to wire up another one, where does it go?
Old Jul 18, 2011 | 04:06 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Altered Ride
The thinner red wire can go to any 12 volt source near the battery.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
