installing new headlight module
Old Jul 30, 2011 | 10:15 AM
VelocitySc0pez's Avatar
Car: 1991 Camaro RS
Engine: 305 V8 TBI
im installing a new headlight module that comes in the mail today. its a 8k low beam conversion kit complete with new housings. I was wondering if theres a thread out there showing you how to replace the module or any info at all would be appreciated. thanks
Old Aug 2, 2011 | 06:03 PM
brooksz2891's Avatar
Car: 1991 CAMARO Z28,'04 BIG DOG CHOPPER
Engine: 350 CUI F.I
Re: installing new headlight module
body
http://www.ehow.com/how_8083036_repl...camaro-rs.html
Old Aug 2, 2011 | 06:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Not sure the ehow about the headlight switch is what he needs.
I'm no expert - but I do know you need to beef up the wiring a tad for anything other than stock 55watt sealed beams, and you need to use relays to power the lights. You want your OEM wiring to "activate" the relays, that will then switch on power directly from battery to the new headlights - that way your not overtaxing the minimal and old factory wiring (fire hazard as well as lights not lighting to full potential).
Do a on headlights or HID and you'll see a ton of threads describing the new wiring "harness" to make yourself with the relays to handle the increased amperage load.
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
How did brooks come up with the thought that a headlight switch on the dash was the same as a headlight module?
3rd gens never came with HIDs stock, so what you are wanting to do there is a custom conversion. Refer to the instructions that came with it for installing in.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
crazynights
Aug 21, 2015 06:53 AM
Fronzizzle
Aug 17, 2015 02:52 PM
stalkier
Aug 13, 2015 12:59 PM
