Where are all of my fusible links located?
Old Aug 7, 2011 | 11:12 AM
transamrob86's Avatar
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
When putting a new engine back in my car, the positive wire was connected to the block and the negative wire to the starter. After frying a computer, I traced the wiring and discovered that problem. Now I get interior lights, but no dash lights, and no fuel pump. I want to check the links that connect all of this before I go tearing wiring out and dropping my fuel tank to replace a fuel pump.
Old Aug 7, 2011 | 02:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Where are all of my fusible links located?
Most of them connect directly to the starter at the same terminal as the pos battery cable. Might be a couple more connected to the power distribution block located between the battery and radiator (down low) - assuming this car has a pass side battery (some were driver side battery, and I don't have a clue on those cars).
Old Aug 8, 2011 | 02:21 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
My car has a driver side battery. 86 firebird.
Old Aug 8, 2011 | 03:23 PM
Pocket's Avatar
Car: 91 Trans Am
Same basic layout
Majority to the starter battery cable lug, rest to the power dist block. Bottom of the rad shroud near the battery or possibly on the pass side near the emissions stuff
gta892000
Aug 11, 2019 11:16 AM
64goatman
Sep 9, 2015 01:09 PM
383cam
Sep 9, 2015 06:01 AM
tonys91rs
Sep 2, 2015 07:07 PM
