Hi-beams stuck ON/Flashing
Old Aug 21, 2011 | 11:51 AM
TA87GTA's Avatar
So I went to the parts store and grabed two NEW sealed beams. One was half filled with water and the other was looking rough so i replaced them. I plugged them in and they both turned on. When I went to turn the headlights OFF I noticed the hi beam indicator on the dash was ON. I tried flipping them to lo-beam and got nothing. After about 10-15 mins of driving the head lights and the hi-beam indicator light starting flashing a TON.
I have no idea where to even start attacking this prob...
PLEASE HELP!!
Old Aug 21, 2011 | 09:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Hi-beams stuck ON/Flashing
I'd start with the hi/lo beam switch, located on the lower steering column just above the brake pedal. When you move the stalk lever, you'll see a rod moving up/down the column into/out of the switch - check it for wiring connector issues, or try replacing it.
Old Aug 22, 2011 | 07:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hey, TA,
Welcome to TGO.
Are you certain you have the correct lamps?
JamesC
Old Aug 26, 2011 | 08:43 PM
TA87GTA's Avatar
So I did some basic troubleshooting and found my problem. @JamesC, it seems I did NOT have the correct lamps. Goes to show how much some of these parts guys really know, huh?
The original sealed beams were a 3100k rating where the replacements I bought were 3300k. I guess the Sylvania Xtravision lights overheated the circuit causing the headlights to flash.
So, I went to another parts store in town and they gave me the correct, standard rating lamps. My beams now switch from hi to lo and I have no more erratic headlight flashing.
Thanks for the advice guys!
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
HikoriYami
Sep 21, 2015 07:11 PM
steimel94
Sep 20, 2015 12:46 PM
ctoledo0834
Sep 18, 2015 04:16 PM
