Please help me solve a couple of wiring issues!
Old Aug 21, 2011 | 10:17 PM
jimmy_pop15's Avatar
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Ok I took the dash out of my car to do some work on it. I put it back and there's one single red wire that comes out of the harness where the highbeam switch and brake light switch come out. i don't remember where it goes. I put the gauge cluster in and none of them move, but the dummy lights work. Also, the door/light chime is making a steady, faint beep that goes to a steady beep for about 3 seconds when I touch the right side connector to the gauges, then goes back to a steady, faint beep. i can make it stop totally when i turn the light switch ON. Also, now the car will start, but not stay running. I would first of all like some help with the red wire which i think may be the main problem. It's a medium gauge, solid red wire with a gray connector, female blade type. Please and thank you.
Old Aug 22, 2011 | 06:21 PM
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Re: Please help me solve a couple of wiring issues!
no help?
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Cleotiz
Jan 6, 2018 08:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86Base
Aug 8, 2015 01:34 PM
