Hatch pulldown motor issue!
Old Sep 7, 2011 | 09:49 AM
IMissMy86TA's Avatar
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
My car has 21K on it so I dont expect the motor is worn out..
I opened the hatch Monday and it wouldnt close. motor does not kick on. nothing else seems affected so I dont think it is a fuse. no one has slammed it. I cleaned the contacts but no luck. motor does not kick on at all. any ideas?
Old Sep 7, 2011 | 11:29 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Hatch pulldown motor issue!
Is the assembly stuck in the up or down position?
I'm just wondering---if it's down, have you tried to flip the limit switch manually?
Old Sep 7, 2011 | 11:31 AM
Engine: 5.0 TPI
How to flip the switch manually?
basically when I bring it down it doesnt latch it just doesnt go down all the way...
Old Sep 7, 2011 | 11:57 AM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
You mean it does latch, it just doesn't pull it down?
Old Sep 8, 2011 | 07:46 AM
Engine: 5.0 TPI
It doesnt latch. it doesnt go down far enuf
Old Sep 22, 2011 | 09:29 AM
Engine: 5.0 TPI
Just wanted to let ya know that its fixed.. Just used the little button next to the latch and brought the motor up.. then closed the hatch and it pulled it down.
Old Sep 25, 2011 | 10:22 AM
richy2001's Avatar
Car: 86 TTOP Black Trans AM
Engine: Base 5 Liter
Transmission: 5 Speed Manual
Axle/Gears: My Car has some
I have hatch issue.on my 86T/AM. I do not see where there is a push button. Hatch became open and motor will not pull down, any help?
Old Sep 26, 2011 | 07:47 AM
Engine: 5.0 TPI
It switch is black.. looks like part of the latch.. just feel around there.. it is there... I had to take off the trim to see it well.. it does not look like a switch... more like a lever...solid black and is vertical. but it is right in the lock..part of it..
Street Lethal
Apr 30, 2019 12:14 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
