vats delete tbi chip ?
Old Sep 11, 2011 | 05:03 PM
ratrapp's Avatar
lost the keys to 91 rs 5.0.i tried the resistor trick(didn't work).i 've done this on several cars before and it always worked but not this time.i got the ecm,vats module and key out of a wrecked 91 rs and measured the key and it was 2.36 so i tried another resistor this same value and it still didn't work.i measued the resistor before and after to verify it was right.i grounded the starter enable relay and it cranks but no start unless i spray starter fluid in it.some sites say you can't get a new/burned prom with a tbi but i thought someone on this board did burn them from tbi cars.i would just like to delete the function by a prom chip if possible.thanks
Old Sep 11, 2011 | 08:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: vats delete tbi chip ?
You can buy a VATS delete module from ebay or Painless (as well as others) for about $50 that bypasses the VATS system both at the relay and at the ECM - would be the cheapest easiest thing to do. Make sure you get one that does both ECM frequencies (I think it's 30Hz and 50Hz) and can be switched between the two.
Old May 23, 2020 | 01:30 PM
AlexChavez's Avatar
how would i go about getting a vats delete module. i have the same issue. appreciate any help
Old May 23, 2020 | 06:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Baker electronics or have a vats bypassed prom made.
Old May 25, 2020 | 09:47 AM
GeneralDisorder's Avatar
It's really simple to burn a VATS delete prom. You can buy all the stuff to do it for like $120 or so including the chip and chip adapter. If you are inclined to do so this is a good time to learn a little about tuning.
Or have Tuned Performance burn you a chip.
GD
nollsracing
Carburetors
Feb 26, 2017 11:28 AM
incontinuity
Aug 21, 2013 03:32 PM
mxanders04
Sep 22, 2012 07:56 PM
utfan01ss
May 9, 2012 12:03 PM
8UpAFord
Apr 11, 2005 11:04 AM
