another blinker problem...
Old Sep 29, 2011 | 12:57 AM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
well tonight i was driving around and this new v6 mustang on 20 or 22s gets next to and i knew he wanted to race so and puttin three car lengths on him i had to come to a stop hard and fast. i stopped in time and i look down at my gauge cluster and notice my right blinker is on but not flashing, and i didnt set it to the right so in my head i said this d### car! well when i went to my house i did a quick inspection and and my left side turn signals work fine but when i put the right side on they dont flash but they are on and the blinker inside the car stays on. so has anybody ever had this problem and what can i do to fix it?
thanks in advance for the help guys
Old Sep 29, 2011 | 05:11 AM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: another blinker problem...
You most likely have a bulb that's out. Take a look around and see which one is out, and replace it. That should fix it.
Old Sep 29, 2011 | 10:00 AM
Car: '90 Camaro
Engine: 305 tbi
yea i forgot to mention i do have a bulb in my side marker on the right side. well ill go to autozone real quick and see if it works.
thanks man
Old Sep 29, 2011 | 11:25 AM
Car: '90 Camaro
Engine: 305 tbi
ok so i checked the bulb and it was fine. but i noticed that when i turn on my head lights thats when the problem happens, but when im driving around in the day time it works fine. so could this be a fuse? i was also told it could be my turn signal lever.
Old Sep 30, 2011 | 03:17 AM
Car: '90 Camaro
Engine: 305 tbi
no one has an answer?
Old Sep 30, 2011 | 01:09 PM
Car: '90 Camaro
Engine: 305 tbi
i have also noticed the whole right side of the cars lights are acting up except the brake lights. man this car is something else
Old Oct 2, 2011 | 04:18 PM
Car: '90 Camaro
Engine: 305 tbi
ahhhhhhh! i feel relieved. turns out i had a couple of wires that were spiced a long long long time ago that were just nasty and lose i fixed them put new wires and now lights work fine.
Old Oct 2, 2011 | 07:40 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
i had simlar issues that turned out to be a disconnected ground in the front light harness. bad bulbs and loose/disconnected grounds can do some funky things with lights.
Old Oct 3, 2011 | 08:32 AM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Mine does that.... Hmm..
Old Oct 3, 2011 | 11:04 AM
Car: '90 Camaro
Engine: 305 tbi
yea i felt kinda dumb cause i posted this up first but i mean i wasnt trying to make the problem first but no one really replied so i did what i had to do. haha, im not good with electrical so thats why i posted first. and yes it does do weird things to your car.
Old Oct 7, 2011 | 12:19 AM
Iroc-Z Tone's Avatar
Car: 1985 Camaro Iroc-Z
Engine: 350 5.7 TPI
mine both work but they seem to get tired of blinking after a few seconds! lol. when I put my blinkers on they blink at normal speed then start slowing down until the blinker just stops blinking & stays on. any idea what it could be?
Old Oct 7, 2011 | 12:30 AM
travis401's Avatar
Car: 91 Camaro RS
could be a warn out flasher
Old Oct 7, 2011 | 05:01 AM
chevydrvr's Avatar
I just replaced my flasher with an electronic one, because I was tired of the sometimes slow, sometimes fast blinking.
Old Oct 12, 2011 | 09:49 PM
Engine: 350 5.7 TPI
it was only my flasher, very easy $6.99 fix! THANK YOU!
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
92fire-audio
Apr 25, 2008 12:06 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
